My thoughts exactlyI'm starting to think khemist has an issue.
My thoughts exactly![]()
And mine!.
Not in this case... first step is new pump, second new block, then just surrender and get the fittings and pipework and rgb everything and a new case and fans and whole rig while you're at it.Well...the first step to a cure is acknowledging you have a problem
Thanks for the address, I'll be over this afternoon for a cuppa
e: Newcastle? Sod that![]()
As I said my comparison to the GTC is an Audi TT so for me it was a worse comparison but as you say it still feels very stable and handles reasonably. I haven't tried the companion app yet, im not sure it will work as I don't have the full infotainment system only the basic radio.
Would be interested in how you get on with this. I like the idea but I'n unsure how secure the devices are from getting nicked if you decide to host externally and whether or not the cloud based platform is as restrictive as some individuals claim.
They look cool, they must have batteries in. How long do they last? How do you recharge them?
Unless you mount them out of reach, they're very easy to nick.
Cloud based platform I'm not fond of personally... I prefer control over it and no subscription for longer storage periods.
They're only 720p...
I picked up some much better resolution HikVision PoE cameras for about £80 each instead.
I just read up on the specifications of the Arlo Pro and a little surprised they're only 720p. Definitely not for me then.
I've had some for a month now and they've used about 4% battery life but that also includes setting up and configuring them.
I have one, so far so good.
Disappointing they are not 1080P, instead 720P and the battery life is not as good as they suggest, certainly at first anyway as you will keep having a nose at your house. But other than that I am pleased with them, find the motion detection and night vision works well and they seem to work with the app really nicely.
They are held onto the supplied magnetic (strong) mounts and would be easy to swipe, suppose it depends where you mount them.
720 and cloud based (free 1gig storage) is fine for me, they're not really for security as such more to watch various wildlife coming and going in the garden
So easy to setup and the app works well as does the night vision and motion detection - batteries should last for months depending on number of activations
They are, in my case, a bit of a gimmick and certainly wouldn't have paid full price for them, but at virtually half price, brand new and unopened I thought I'd give them a whirl
So far, so good![]()
Those Bluetooth earphones are surprisingly good for the money and a great fit in the ear.
For just over £20 they are very nice. I thought they would be cr@p but I was wrong.Those Bluetooth earphones are surprisingly good for the money and a great fit in the ear.
lol, just about the right amount. I just need a spare power socket now to use themThose are alright, but still too many USB ports.![]()
My ebike is getting old & rusty so I'm getting bits in to build a new one.
Current motor is just 200 watt so this should kick arse somewhat !
Gotta save up for the battery which is nigh on double the cost of the hub !
