Oculus Rift
15 Nov 2003
Marlow
Currently, once you delete them they're gone forever from Oculus Home - you can not yet undo this, and this was both in the patch notes and in the warning you get before removing it. People say they've been able to restore things manually though (not tried that myself). It will of course not uninstall the entire program.
That's bizarre considering it's got things listed in the library I don't want in there (eg: GuardianBoundayEditor.exe)... The fact you can't even reorganise the library into folders is a real weakness too!
20 Nov 2008
South Yorkshire
Anyone got a link to some VR videos I can download and try to a VR player for the Oculus?
I generally don't bother with VR video (and I'm in the camp that 360 video isn't VR) as it's pretty much universally bad quality. However if you want one that's just about watchable (and especially if you were a kid in the 80's), take a look at Miyubi. It's a stand-alone app, so no video player required.
20 Nov 2008
South Yorkshire
Allumette is nicely done too, although i've only watched it on psvr.
It is, but it's realtime, not a video. Realtime stuff can be really good (Henry, Lost, Invasion etc), but video is generally pretty terrible. There's a hybrid type one on PSVR called the Joshua Bell experience. What they did there was to video the two musicians separately at a hi resolution and 60fps, and then composite them back into the scene which they were filmed in which was reconstructed in proper 3d via photogrammetry.
21 Oct 2002
Earth
Yeah wasn't quite sure what to class it as, that invasion one was good too. Will check out the others you've mentioned :)
@Devrij SLR ?? (i know i'm going to regret that :D )
11 Jun 2013
Nottingham
The video (whether 3D or 360) is pretty meh in my experience. For 360 video you'd need massive files to keep any semblance of sharpness across the frame, and for 3D it takes a lot of faffing to pick a workable mode and settings that work okay-ish for the given video, as the usable area for objects flying out of the screen is pretty small (or you'd see them with one eye only) and not every size of viewing distance might work for every video. Even after all that is solved (and Miyubu is so far the only video I've seen that has decent quality) it's still jarring to me that the camera position is fixed.
You can try Bigscreen Beta to play with it.
15 Nov 2003
Marlow
Yep, I really am just after some 3d VR videos to try.
15 Nov 2003
Marlow
Tried oculus tray tool yesterday.
I ran a couple of VR demos with default super sampling and then it set to 1.5. Couldn't see any difference and indeed the GPU usage was unchanged too?
11 Jun 2013
Nottingham
Did you change the super sampling before starting these VR demos? You can't change it on the fly. Also, the difference would be subtle and best seen side by side, but it can make text more easily readable in particular.
15 Nov 2003
Marlow
Yes.. Even stopped and restarted the Oculus service using the tool too? Surely I should notice a GPU hit at least?
11 Jun 2013
Nottingham
Depends what you are running it with, I guess?
Edit: this thread has some example screenshots: https://forums.oculus.com/community/discussion/51256/pixel-density-examples
Also, you should be able to verify current settings with the overlays available through the tray tool (the overlays and the pixel density settings are actually done through the oculus debug tool, the tray tool just makes it a lot easier).
3 Aug 2010
Anyone else has disabled Spud on the Rift? It made a massive improvement for me on dark scenes, there is no way I could go back to having it on. It fixed all my annoyances.
Permabanned
1 Jun 2004
London
