Poll: The Vega Review Thread.
What do we think about Vega?
  • What has AMD been doing for the past 1-2 years?
  • It consumes how many watts and is how loud!!!
  • It is not that bad.
  • Want to buy but put off by pricing and warranty.
  • I will be buying one for sure (I own a Freesync monitor so have little choice).
  • Better red than dead.
Results are only viewable after voting.
But your not comparing like for like. A RX Vega 64 liquid edition comes with it's own self contained water cooler where as the 1080Ti comes with a conventional heatsink and fan design. The Vega 64 is around 1080 performance so if a RX Vega 64 costs £650 with an AIO how much does a GTX1080 costs with an AIO? Well looking at the store the Gigiabyte model costs exactly the same.
If you want to moan about pricing then you should be pointing out that you can by an el cheapo GTX1080 for £450 that has a blower style cooler whereas the cheapest RX Vega 64 start at around £548 that has a similer style cooler (the RX Vega might have vapor chamber on it though).
Well said.
I would like to see what happens when you run a 1080ti @ 1650mhz versus a RX vega at the same GPU speed. Has anyone done a video ?
I am very stunned to see 3 people bought PowerColor RX Vega 64 Liquid Edition for £779.99 that are £120 more expensive and 30% slower than Gigabyte GTX 1080 Ti at £659.99.
Madness! :eek::o
30% slower than a 1080Ti at what?
Maybe gamers are going to be kept off these cards by people who don't use them as toys and find the price trivial.
Vega 64 is cheaper than the Vega FE and disgustingly cheaper than the Pro Nvidia cards and still topping the lists for certain workloads.
No, please don't say that. Going to have nightmares tonight... H1 2019 means Q3 2019 to AMD.
I hope so :)
I have seen a lot of people be very harsh on him online due to Vega, saying silly things like fire him etc. But I won't judge the man's work until Navi and even then if it cannot beat Volta, people need to understand he has a lot less R&D money than Nvidia.
I don't think Raja should be judged on Vega either. By all means it was in development before he returned to AMD and probably well in development by the time he got back up running again. Vega was originally codenamed Greenland which was first mentioned around 2014/15. Vega is GCN based and most likely Navi will be as well, GCN is quite an old architecture now being around for 6 years, there might not be much more he can do to turn it around without a redesign. Hopefully the architecture after Navi will be a departure from GCN and will allow him to show what he's capable of.
I dont think they will drop or see the need. The plan is probably make profits now to pay for Volta then use that to beat any future contenders.
But if they did want to destroy then:
1050 - £75
1060 - £160
1070 - £270
1080 - £380
I still don't think that is enough of a drop to make up for the G-sync mugging :p
Why should you need to when a gtx 1080Ti doesn't need a watercooling solution to begin with?
Because it's important to compare like for like, and because Vega and the GTX1080 don't either.
IF you're arguing that the AIO version of the Vega 64 is rubbish because it costs (or did before pricing went lol) the same as a hairdryer spec 1080ti then you're also arguing that the AIO GTX1080's are rubbish too. This is why apples/oranges comparisons don't work.
Sorry but your argument does hold true. These are specific and approved settings selected at the driver level using Wattman, and or via the BIOS switch. In short these lower TDP settings are officially approved and supported by AMD on the RX Vega and by definition should be attainable by every Vega 64 sold. This is not an individual going in to Wattman and lowering voltages to unrealistic levels where the card becomes unstable.
Most reviews I have read barely mention the lower TDP settings and one review even went as far as only testing Turbo mode and getting obviously crap TDP. AMD setting RX Vega to lower TDP of 214 W for ~5% less performance and 80 W less consumption would have made TDP look far more attractive. These numbers are not made up, check out the TPU review.
I'm not defending how poor stock TDP is and do feel AMD messed up their priorities. At stock OOB the Vega 64 has horrendous performance per watt, but it's wrong to ignore there are other TDP setting that paint a much better image.
The settings are approved but the performance differences may vary.
Otherwise explain why AMD would purposely set voltage and power levels that achieve no meaningful performance gains.
AMD will have tested thousands of chips and and done a lots of calculations and simulations to find exact voltage and power settings to achieve desired performances and yields. They didn't randomly pick settings that make Vega look terrible for no reason
LOL!
Agreed.
You do understand there are people who use computers for things other than gaming right? If the cards are considerably cheaper than equally/worse performing cards for workstation use then it makes sense professionals would be interested.
I mean, the fact remains that despite the pricing going full retard these things are still selling like hotcakes and it's damn sure not miners this time so that only leaves gamers/professionals.
That's not really the point.
I then decided to buy a bigger psu so I phoned back in and they took another £140 from my account at 39 minutes past 2pm
I thought it was known that the psu over 650w was not needed. Only Liquid could use that much and even then power is capped off.
You could turn a negative to a positive and buy the ti or dont buy the psu and buy the 56 then buy Navi when it appears or even Volta. Keep your options open
The WC version is beyond a joke unless it turns out to ramp up to near 2Ghz once AMD have sorted out their software. Incredibly unlikely though, eh.
They capped power or one reviewer I think said yes its feasible as the card components are engineered to handle just about anything. I wonder how people like 8pack might deal with it.
Obviously those are the extremes, the sweet spot is not near 2ghz its a 1080 contender.
The future gains for Vega I think are in efficiency and reducing load on their pipeline which helps power and the ghz rise that way, or thats how it sounded.
The Nexus interview with an AMD guy he seemed adamant that Vega can be 1.7ghz at least with boosting above that. I would guess he was frustrated at not being near this 2ghz as you say
Yes I do. Correct me if I am wrong however, most people here are interested in gaming side of things, since when did we worry about compute in these forums? ;)
Everyone is talking about games, guy pops out charts to support his argument that are based on compute. Surely you see the funny side of that? :p
It's more ROP's that AMD need, 1080Ti has about 40% higher fillrate, not everything in GPU is compute dependent, drawing pixels happens to be extremely important in gaming.
If you look back at some Fury X rumour articles before it was a known quantity there were somewhat ambitious rumours about it having 128 ROP's, as it turned out it had the same number as AMD have had since 290X and they've not improved it with Vega either.
Guy is expressing surprise that cards are selling despite being less powerful than a 1080Ti.
Other guy posts evidence of situations where Vega 64 is in fact much more powerful than a 1080Ti and thus it wins at performance and price.
Thus presenting a decent reason for Vega 64's to be selling despite gamer mentality that it shouldn't because FPS :p
You follow me? ;)
I do, and it's also good to see these selling full stop. Not that it's a long term indication of how they'll do, and of course if gamers aren't buying them then that would be detrimental as what incentive would devs have to optimise better for the architecture?
