Yep, my first ever computer 'mod' was feeling like a God when upgrading it to 1mb ram!True that and the Amiga was far better![]()
I think at the moment HBCC only doubles your vram presently. That's what I remember hearing/reading.
Well I'm sure that not everyone I've seen seemed to think 4GB HBM was a problem. So from my point-of-view/memory I'm not twisting history. What you've seen may lead you to a different conclusion, I can't base my posts on what you saw.The answer to your question as to why they didn't put 4GB is probably that they found 8GB to be good a buffer, between feeding the gpu and moving data across and power. The issue with the 970 was that Nvidia hid this information and didn't mention it. Also I'm pretty certain that everyone i've seen when talking about the fury say that it should have had more memory so stop trying to twist history to make a point. Your penultimate point has nothing to do with this.
Overpriced for game. Yes I agree, but for compute its right where it should be.
DittoWhat a silly post.
But there's got to be a performance hit from using HDD space, even with HBCC hasn't there?They is a massive difference between running from system ram/HDD vs the High Bandwidth "Cache Controller"
The key difference between then and now is how the cache controller handles the data.
Just like how HDD with SSD cache work to speed up transfer speeds.
My point being that because 0.5GB of the 970's VRAM ran slower a huge number of people complained about it. When AMD implement a system to use slower memory it's a 'feature' and people love it. I realise that at least some people were annoyed because Nvidia misrepresented/lied about some of the numbers, but a lot of people seemed happy with the cards until this issue was raised, it's not like they noticed the problem.
If a game needs 10GB VRAM I'd rather have an 11GB DDR5X 1080Ti than an 8GB RX Vega 64 with HBCC. If a game needs 12GB VRAM, well then I'd probably want a new card with 16GB VRAM rather than 8GB and HBCC. Much like if a program needs 10GB system RAM I'd rather have 16GB DDR3 than 8GB DDR4 and use the swap file.
I guess some people will just love everything AMD do because AMD do it. Currently I think Vega is decent but 12 months late and probably too expensive. Also, it'd be nice if it was more efficient.
If I was buying 1 card I'd buy a 1080Ti. If I was then buying a 2nd card for a different PC I'd be tempted with a Vega, but currently for me it's looking like a repeat of the last gen card, Nvidia have just pipped it.
Both HBCC and Pascal unified memory support 49-bit address space (which is 512TB or something) though the CPU IIRC has slightly lower limits - I'm guessing this is to cover both GPU resident storage as well as system storage in general.
The biggest impact of this will be professional compute - I'll be very surprised if there is any meaningful impact on gaming any time soon.
From my understanding the point of HBCC is to swap out data that is not being actively used. In theory it should fetch data from the RAM/HDD before the GPU needs to run calculations on it (There will be misses at times). This is different to the 970 issue because the slow down came because the GPU was trying to access data that it wanted to process at that point in time. They are in no way equivalent situations.
What the point in having 16GB of RAM on you system and on your GPU when most of it isn't being actively used? All you do is increase system cost and power usage.
Edit: This guy rendered a 50GB scene with a VEGA card thanks to HBCC. Such a scene wouldn't even load on Nvidia card unless it has enough VRAM. Wonder how much that would cost.
https://blenderartists.org/forum/showthread.php?426522-AMD-RX-Vega/page7&p=3230126#post3230126
50GB scene of what?From my understanding the point of HBCC is to swap out data that is not being actively used. In theory it should fetch data from the RAM/HDD before the GPU needs to run calculations on it (There will be misses at times). This is different to the 970 issue because the slow down came because the GPU was trying to access data that it wanted to process at that point in time. They are in no way equivalent situations.
Maybe it's just me, but if I were going to get a Vega card I'd want a Vega 64 (either AIO, 3rd party or WC'd). The Vega 56, while better, doesn't seem like a huge step up from the Fury X I'm running currently (and currently I'm running Fury X CF).Might be a simple question for some of you but does the Vega56 now finally come with 4K HDR over HDMI?
Looking for something to replace my nano. Vega56 seems like the only worthwhile new gpu from AMD.
Not sure why everyone seems so keen on the 56, what am I missing?
The problem for AMD will come when HBMx is actually cheap and widely available, then Nvidia can get the same power savings, just think how absolutely horrific Vega would seem if Pascal used HBM2 and draw 40w less!
This is absurd. Since when did people's relationship with AMD/NVIDIA develop so deeply as to start arguing points such as 'anything I do is never good enough" and "somehow you can never do wrong".
There is no reason to think AMD cant make up the technical deficit between them and Nvidia like they did with Ryzen and Intel.
You can jump more than one step at once.
