- 19 Oct 2002
- Shakespeare’s County
Yeah and autobrite top gloss. Nice to run an open hose for a final rinse to get most spots off. Doesn't really last that well though.
Great thanks!Auto Finesse Crystal or Autosmart Glass Clear
The gel will last much longer, I've tried both and AG doesn't get a look in now for tyre dressing.Looks great. After application they look identical but as you mention it's the longevity that counts! It smells unreal for those who sniff tyres which is a pro i guess![]()
The Bilt Hamber auto wheels is amazing, pretty much a touchless clean, may as well just order the 5 litre straight off as you'll definitely want more after that bottle runs out!
I've got the 5ltr container and it'll last me a year.Any recommedations for snow foam pre-wash. Just finished off a bottle the Chemical Guys Honeydew. Works well but requires a large amount to get a nice thick foam. Cleaning wise was reasonably impressed but heard good things about Bilt Hamber snow foam. Any others worth considering? Thanks
Autobrite Magifoam - need only an inch of liquid in the bottle, the rest water and you can make creamy-thick snow foam all over 2-3 cars.
Washing the cars yesterday I put a wool mitt on each hand - double speed! And I tried using BSD as a drying aid, it worked fantastically well.
