Overall budget first?
/Meanwhile Orbital specs a G-Sync 4K with GTX 1080Ti![]()
NO, definitely not! You only need a 1440p max - idealy with G-sync - but i need that max budget.I’m not sure. You saying I need a better monitor, what a 4K one?
That’s nice! Would I notice the difference from 144hz to 165hz?If you dropped to a Ryzen 1600 and a GTX 1070 you could get an excellent monitor that would compliment the build really well - great panel: G-SYnc @ 165HZ.
stulid did a pretty comprehensive review - Clicky
My basket at Overclockers UK:
No, but G-sync and quality of panel, yes.That’s nice! Would I notice the difference from 144hz to 165hz?
Wise if funds are tight.I might have to stick with that first monitor for now
But you really don't need a GTX 1080 for 1080p gaming - i would definitely save some money and buy a GTX 1070.
Gigabyte - for the Customer Service and UK RMA.There seems to be a lot of different 1070 cards....which one?
About £70 difference?
The
Acer XG270HU 27 inch 144Hz WQHD ZeroFrame 2K Gaming Monitor looks good. Found it for £370
