thanksI don't know the differences between the bios. It's possible that the AIO has high voltage and TDP limits and is better binned.
Just done a 20 minute bench of Firestrike, with a few overlays on screen for you guys to see what settings I'm at for future reference if needed. I've now dropped my core and voltage a tad for definite stability, this will be final 24/7 settings for gaming now. I've benched at 1750/1100 so at 1700/1080 it's given it a bit of breathing space.
I'm very impressed with the absolute solid core and memory clock speeds, just no dips or fluctuations at all. Interestingly only 63c on the Hotspot in GPU-Z and a max core temp of 39c and max HBM temp of 40c.
click for a big one
Man those flat lines are fit. I copied your settings on my v64 Liquid stock but with +25% pwr (can't see your setting but my PSU won't do +50) and my lines are more like the Alps. I wish I could just use someone else's settings to be honest. Tinkering is alright up to a point. How about I send you my whole PC and you send it back with really flat Wattman lines?![]()
I'm sure it has been discussed before, but what directions do what on the tiny switch by the bracket/output end of the card?
My HBM voltage testing was on public drivers.
One of my vega 64's... Dead on arrival :|
and another
They're mounting up!
I know we only really hear when it goes wrong but still too many reporting issues.
Adjusting HBM voltage triggers a bug which I've reported, that's what i was referring to Dave.Do you have a link to your testing?
The 64's are overvolted to 1.35v out the box.
If you are referencing the memory voltage in wattman then that isn't linked to the working operating voltage.
Bur if you are modifying the powertables and registries to control the hbm voltage regulator, do you have special drivers or tools ?
1750Mhz on the coor 8134 points on 3d mark time spy graphic test
First of all, im new here so Hi.
Second, @TonyTurbo78 Nice clocks bro, gonna aim for the same things. I assume you have the AC version ? Of is it LC ? Your temps do make me think its the LC ? Oh and IF it's the AC, what are your fan settings.
Edit:
