Permabanned
- 12 Dec 2012
Its not in the pause menu.
@Marky You maybe on to something but i am scared to do that as it may just exit the race and thats it lol
Its definitely in the pause menu
Got it at 85 which I perfect for me just now.
In the old game I was stuck between 2 difficulties......very anoying.
Most the bugs are getting fixed rapid, today sorted the 25% race wear bug so imo just the AA needs addressed and its how it should have launched.
Pretty good so far. Has anyone managed to pass the Tyre Management in practise using mouse/kb?
Just buy a game pad, if you cant justify a full wheel/pedal setup, it will make your game experience so much more enjoyable and make driving much easier, being able to feather throttle/brake and vary the steering angle is essential, game pad wont give the same level of control as a wheel but its lightyears better than keyboard.It's actually pretty decent using the keyboard, I can't really justify getting a wheel/pedals for it.
Is there such a thing as a decent wheel without pedals?
With a T500RS, sat on the grid and it tells me to hold down the clutch, raise the revs and slowly release which is exactly what I do. Foot on the clutch pedal (Fanatec Clubsport v3s) and then slowly release it but nothing, I just sit there. Have tried pulling in the gear up paddle but nope nothing there either. Have resorted to just doing time runs and other stuff until I can figure it out haVery much this, I was completely confused as to what I was doing at the start.I just hold the up shift paddle then release at lights out then up gears as normal on g29.
22nd Septemberwhen si pc2 out?
22nd September
Apparently the McLarens are bugged in career mode and engine upgrades do nothing... you couldn't make that up! They're going to fix it but you can put dev points into other areas in the meantime.
