Still don't see them as legit issues. It's as if people are expecting something beyond what needs to be released based upon the competition. Don't like it, buy ryzen and put up with its own set of issues which to me are worse.
?What are these Ryzen issues? Other than having to put up with 100fps rather than 120fps?
There are many issues
I'm still having them to this day.
Once I sorted memory and stable overclock I have none.
Constant bootlooping when booting from cold and I know I'm not the only one with this. My OC is solid, its this **** training process it goes through.
I'm also pretty certain that I have one of the CPU's affected with the segfaults bug as I got this on release day.
Have you seen the hoops you need to jump through for AMD to even consider sending you a chip?Contact AMD, and they'll send you a newer fault free CPU. No need to suffer with a bad chip.
You have a dodgy chip and you're unwilling to RMA it?
That ^^ is nothing unusual, they have to rule out PEBUK before they let you go through the expense of sending it to them only for them to find you had a setting wrong.
Its not difficult to provide them with all of that.
I'm not sure if it is dodgy I've never tested it by compiling anything. Its fine for normal use.
AMD seem reluctant to accept it as a fault and ask for screenshots of bios settings and whatnot trying to blame segfaults on overheating.
AMD's response potential RMAs
- Thank you for submitting your RMA. I'm sorry to hear that you're experiencing stability issues with your system. Please be assured that I am here to help find a resolution to your problem
- Before approving your RMA, I would like to firstly perform some troubleshooting and focus on your system's hardware configuration.
- Please provide the details of the following hardware components in your system:
- • Make and model of motherboard
- • Motherboard BIOS version
- • Make and model of RAM
- • Make and model of the power supply unit
- Please could you let me know the current settings you have for the CPU VCORE, SOC, and RAM? It would be very helpful if you could provide with pictures of your BIOS screens with these settings.
- In addition, through troubleshooting with other customers we have found that the layout of the components inside the system case have caused sub-optimal cooling of the CPU causing a variety of issues.
- I would like to better understand your system cooling to rule out any thermal issues. Please could you provide a picture of the whole interior of your system showing the CPU cooler?
- Also, could you let me know the reported CPU temperature during heavy load or when the errors occur?
- Please be informed if we do not receive response to this email within next 10 days, your service request will get closed automatically in our system and you will be required to create new service request on your issue again.
You do know that the most common cause of a segfault is incorrectly set ram, or bad ram ? That in itself would cause constant bootlooping. Have you seen a segfault warning on your screen ?
