I'm fairly sure the common name is 'the small plastic/rubber sleeve jobbie thingymabob from the rear mech' in any LBS workshopCan anyone advise what the small plastic/rubber sleeve that sits inside the barrel adjuster on the rear mech is called?
Doh! Awkward and very disappointing to know his performance was compromised over it!Could be worse, you could be my friend who flew out to do Ironman 70.3 in Chatanooga last weekend, swam a great leg, got to his bike and his Di2 although fully charged the night before was dead. Ran back to his hotel got his charger, but the system was died, managed to borrow a bike and finish in time limit though, but he was hoping to qualify for worlds like he did a couple of years ago!
I was always under the impression the calorie burn was more closely linked to HR (actual effort) than power (results of effort). You could be on absolute flier of a day and easily pushing 300W in Z2 burning next to nothing (on top of the world!), yet another day utterly emptying yourself into a headwind at 300W and Z4 just to make (slow) progress. Efficiency is key to the burn (I think?), that first day you're hitting maybe as high as 90% and the bad day you're at something like 65%. Strava I think works it out from intensity which comes directly from your power data/zone, not your HR data?What's the weight difference between them? I'd look at the estimated power output (or actual if you have a PM, presumably not though) and times the average (not the weighted average) by 3.6. Rather than the calorie projection.
On a similar topic I'm trying to find a study or explanation to back up whether power output is a complete absolute or whether heart-rate variance carries any bearing on calorie expenditure. My logic is that when on the extensions on my TT bike my HR is higher and I am less efficient so for the same given power as my roadie my HR is higher. Whilst no extra energy (watts) are being produced the load on my CV system and bodies attempts to cool are higher which I should think carries some extra caloric burden?...
I'm not using any more energy but I'm less efficient which must indicate a marginally higher burn?
It mainly depends on the bike category as it uses that as a best guess on the type of terrain you are riding on. Therefore for the same ride the calorie burn will be lowest on a road bike, higher on a cylocross and higher still on a MTB. Even is the weights of the three bikes were set the same.Does anyone know how the calorie calculation works on strava when changing bikes? I don't ever use it, but seems to vary massively, with my Pinnacle recording 239, Ridley 153, Felt 149, Cannondale 153 and Scott 239 also. Is it literally just on the record weight of your bike?
Fully loaded up with guards & saddle bag running mitch pro4e 28's on the Axis4.0 wheels it comes in at 11.5kg. The wheels weighed alone (with tyres & cassette) are 3.1kg so most of my weight is there (& will only get heavier with winter tyres!).
My Defy with TT bars, no guards, RS81's, gp4000sii and the same saddle bag is 10kg. Considering they're a light wheelset there's not quite the difference I was expecting!![]()
I agree with FT - I weigh more, too, so I would most likely have a higher calorific burn than someone outputting the same power, no? Normally, you'd be able to work that out through load/ HR, surely? If I'm doing 200w, and at 170bpm, I'll be burning more calories than someone easily putting out 200w and hovering at 100bpm.
That would make sense?
OK, I hear you.
So why do people use fitbits etc for general activities? Genuine question lol not trying to be a ****, I'm interested.
Edited for you.Would be 8kg if you didn't have your saddle bag on there
Mine's 6.6kg - Do I win a prize? Then my beergut weighs 100kg, so that kinda counters it.
You're probably right, but 300W can feel different and can tax you differently - specifically depending on energy & fatigue levels.Surely 300w is 300w regardless of the weather, gradient, cycle of the moon.
Maybe it's just me, but if I try and hold 300w then I sweat - a lot.
To be fair it's probably a combination of the two - the 'exchange rate' of riding power from energy, with positions, conditions & fatigue all having an impact. The physiological load on the body probably having an impact on recovery by similar exchange rates also determined by fatigue and conditions which in turn impact the initial exchange rate.I had worked on the presumption that, with power being an objective measure of work done HR was largely irrelevant. That said if you treat it a little like currency there is an 'exchange rate' between power produced and intensity/HR some days, positions or conditions (sick/fatigued, TT position or low inertia for instance) it'll be less favourable.
Perhaps we're looking at the wrong end of the stick and the burn is no different but the 'exchange rate' so to speak is physiological load on the body. Being greater due to requiring more recovery time as a result of more time spent in higher HR zones.
Yeah but PWM and HRM data would show the results of this - i.e. more power and effort to sustain the same momentum.It wouldn't surprise me if simply changing what type of bike under "gear" has an effect upon Strava's estimates, being more upright on a mountain bike is going to ramp up the aero drag as you get faster.
Meh. I explained it a little wrong from what I was trying to imply - I always thought efficiency varied quite a bit and power obviously doesn't show that, I kinda expected HR to be the only real measure of contributors, like fatigue?Calorie burn varied for the same power? Only of your efficiency is varying massively. As for heart rate - it's utterly useless for measuring calorie burn as it gives no idea of what energy you were expending - to get an idea of energy expenditure you would need to measure.. Power
