Yes.Thanks. I'll give it a go but before I do, am I right to think that since all these V64 LC cards (and AC) are reference designs then a Powercolor BIOS will be fine on a Sapphire card?
It's true that most of the AOI cards don't seem to quite hit 1750 - I can get mine up to about 1730 when running Timespy but in games it's much more common to see the clock fluctuate between 1670 and 1715. There are more exceptional cards around that will go over 1750, AMDMatt from this forum has a card that will hit 1800+ and also TurboTony who has his ref air card under a custom water loop. Mind you we can all set the actual clock to 1750 in Wattman, it's just that the boost clock rarely goes that high. Is your card actually hitting 1750 when gaming/benching?So I'm trying to challenge nvidias dominance in luxmark, but I see I will be failing in a minute. Funny thing is when I tried googling Vega 64 overclocking, resulted sites are posting 1700Mhz or 1716Mhz as overclocking achievement, while my sample runs happily at 1750Mhz@1100mV all day long, even folding. Is the a thread here with you guys overclocking successes and failures, or do I need to read the whole thread here?
Oh, before I forget:
P.S. you image attachment is broken in this forum
Whatever I set on wattman, it stays pinned when folding to that frequency
You can toggle the switch in Wattman to change it from percentage adjustment to manual. Never heard of folding before by the way!What I do not like about wattman is AMDs fettish of percentage clock adjustment. What happened to good old MHz when clocking your cards? Also, why is cooler fan disregarding my set limits of max RPM?
Some interesting results here from Hardware unboxed.
i7 770K Vs Ryzen 1600
benching
RX Vega 64 Vs GTX 1080 @ 1080P/1440P.
Playing this myself just now. Do you have it capped at 60 FPS? I ask because I'm getting a higher average than that at 3440x1440p with everything maxed (apart from motion blur). I have seen it dip into the late 40's once or twice but it usually sits at around 67 outdoors and over 100 sometimes indoors.Not sure if performance gets worse latter on but Dishonoured 2 runs well on Vega.
Also all maxed out only turned down shadows to high to keep frame rate dropping under 60fps when overlooking large areas.
Just got a Vega64 , need to buy a block for it now as the loudness is crazy lol.
I don't find the noise to be overly annoying really ... had a blower type 5870 back in the day, those things were noisy!
