Go Ryzen 7 or Threadripper then, but be warned that IOMMU isn't exactly hassle free on either of those platforms yet. Ironically it works well on Intel's platforms.
But if AMD is a must, 1700X is a good choice and it seems to be priced quite alright nowadays, 4Ghz isn't assured, but 3.9Ghz shouldn't be difficult to get.
You sure about IOMmU support bud?...
(snip)
Memory. Cba chasing them gains. Learnt from years ago its all like 1 or 2 fps at best, lots of effort. Stick it on xmp or woteva and let the mbrd config it. Best set to get? Highest speed but highest compatibility? 2x8 pref
It's to do with the IOMmU grouping, they lumped everything in the same group so you can't (for example) boot from the second gfx slot and pass through the primary or whatever. Some vendors are working on fixes for it apparently, and Wendel has released something of a patch for now. As for RAM, you can't go far wrong with the 8Pack edition TeamGroup 3200c14 stuff. You need Samsung B-Die mems for Ryzen ideally (which it is). Because of its 'infinity fabric' mesh design Ryzen speed scales with RAM speed, so there are definite gains when you climb up the MHz ladder. On a good board you can get decent speeds now the EFI are starting to mature.
I prefer corsair. Any of them sets recommended pls.
(Great info btw guys thanks)
AFAIK Corsair is all Hynix and therefore not recommended for Ryzen.
What size are you looking for? I posted a thread in memory asking about 16Gb sticks and it seems the Trident Z stuff with the B Die IC offers the best peformance for the money.
If you are lucky enough to get some Ver. 4.31 it is Samsung B-Die. When I built my first batch of Ryzen rigs I had loads of it, now it's mostly Ver 5.39, so not as good.
I got corsair lpx 3200 initially, would only be completely stable at 2933, if spending that much spend the extra to get quality b die ram.
Yes, what I am is saying is LPX Ver 4.31 is B-die, newer kits tend to be Ver 5.39 which is Hynix. Check the sticker on your RAM modules, or on the box, it will have the Ver # printed on it.
Mine are V5.39 like most new ones. Didn't know that until I bought them unfortunately.
Some motherboards have not all did tho. Thankfully we still have enthusiasts working within the industry it seems.
Thanks mate.
If you get time, or if you cba. Try removing the PSU cable after its been on for a while. This has a 100% record of getting my memory to fail training.
To get around this, I boot into bios with default values and load the overclock profile and all is fine again.
At the tightest stable settings 3466 is F9 about 1 in 3. So sadly whilst looking promising ultimately no good. I may try some further tweaks at some point but unlikely to solve it. AGESA .7 on the horizon so see whether that brings anything to the table.
Though I know it won't do it again later.
