Permabanned
- 23 Apr 2014
- Hertfordshire
I have lost track what people are arguing about now.
You're probably best asking Voidshatter which ones don't.
Here. https://forums.overclockers.co.uk/threads/1366-x58-xeon-5650.18618052/
Lots of people to argue with. Enjoy.
I have lost track what people are arguing about now.![]()
Should you upgrade a 6 core CPU, motherboard and RAM to another 6 core platform with a little more performance or to a platform with more cores.
Does this person actually "need" an upgrade?![]()
Just another thread been turned into a AMD vs intel.
So far all weve worked out is ryzen is haswell with lower clocks and double the cores.
8700k is 7700k with 2 extra cores, slight bump in clocks, still runs hot and isn't soldered.
Benchmarks show 8700k faster than 1800x in single core by 25% and slower in multi by 5% at stock clocks for both.
141 pages and this is all we have to show for it![]()
I like what you're trying to do. Ryzen is the same as Haswell and these benchmarks yov've seen in your crystal ball show Coffee lake to be 25% faster than Ryzen.
So Coffee lake must be at least a 25% jump in performance over Haswell and overclock to great heights right? Erm no.
Going by the leaked cinebench results, they are there for all to see. A few of us also chimed in yesterday and showed that single core performance was haswell level, clock for clock.
Neither if it's clocked at 4 or above with some reasonable memory.
I've said all along these are from the leaked benchmarks. We will obviously have to wait things other than cinebench.
25% comes from the single threaded cinebench score. Which obviously comes from the higher clocks. In fact when you take into account that haswell clocks higher than ryzen, haswell is actually faster.
Unless Coffee lake is a huge departure from Intels design any gain can only come from clock speed, not core performance. Trying to imply otherwise will only lead to great disapointment.
And where did i say otherwise? I am well aware that the increase comes from clockspeed.
Ok, so ryzen is 5% faster than haswell clock for clock. Except haswell clocks higher...
I thought your only interest was games? or is Cinebench in single threaded mode only now the only thing that's important?
