No, not when used as an ingredient in such small dilution it isn't (not according to regs/guidelines anyway), just like CocaCola, Tap Water and Shampoo aren't despite also containing ingredients that on their own in concentration will harm the environment (Phosphoric Acid, Fluoride and Formaldehyde respectively).However, it is still harmful to the environment
In that case you should report them for incompetence. If they really think that minute traces of a food additive isn't safe to go down the sewer then I'm interested to hear where they think it goes after human consumption XDI showed the "sewer people" EXACTLY what the product was, pointed out the label detailing volume and ZnO percentage and even took them to the website.
They know exactly what it is and they still said no, for the reasons already given.
Here is a simple explanation from another source as you won't listen to reason from me:
- Waste of salts of titanium, chromium in the +3 oxidation state, manganese, copper and zinc is moderately toxic for the environment. Quantities in the order of magnitude of 100 mg per day may be flushed down the drain with a lot of water, but larger quantities must be brought to a waste processing facility.
So again, it's perfectly fine to flush small amounts (or in this case miniscule amounts) down the drain, just don't be putting industrial amounts down there or you can be fined.
