The motorcycle boots he has, cover the ankles unless you meant the shin?Those exposed ankles...
...That crappy Instagram blur filter...
How dare you that's a Raymond Lin original!
Bit chilly on the hands this morning, might have to buy the heated gloves soon... I have no heated grips on the VFR.
Also my VFR has recently started resetting the dash (clock/trips) when starting it, it never fails to start but it's annoying having to reset the clock every few days. It did it this morning just as I turned it on before starting it! Sign of a dying battery? I'll start putting it on the optimiser overnight and see if it still does it.
I think that's a different issue, mine don't actually turn off but lose power for a split second. A lot of people saying it's the sign of a dying battery looking on VFR forums.There's a common problem on that model vfr with the LCD part of the clocks, if I remember correctly it's a dry joint on one of the circuit boards. Might not be the same fault you're having but worth a look.
I have my heated gloves which I’ve never even used, discount going if you want them.
I think they are Large, I’ll have to check.
They are the Gerbing xrs-12 heated gloves.
That tail, the hell! Eww. It's like a Bob Ross painting starting from the front only he hasn't had time to 'save' it on the back.
Nice, nice, nice, RUINED!![]()
