- 2 Sep 2014
- West midlands
You have to use DDU to uninstall as it also cleans some reg keys, but you only need to reinstall if more than one GPU gets detected by DDU.
Ok
Hello,
I had to double take when I saw this loop its not been setup right surely? Should be Res>CPU>GPU>RAD Or Res>RAD>CPU>GPU>RES.
You are going to get much higher temperatures with that setup.
I use wattman and have no problems watt so ever
Thank to the 64 bios i am now running at 1675/1000 but i managed to get it running at 1655/1100 with 1200 p6/p7 and 100% fans this card is amazing!!!
When i get home im gonna see what this +200% does to that, and then i have to stop playing with it or i feel im gonna break it.
Until i get the AIO cooler for it that is![]()
Thanks for the sarcastic post, but if you actually read the search results you would see there is only one uk shop that sells it, the second result is american and the rest are reviews.
Thank you silversurfer I will do that.Im not sure they are allowed to post competitors or mention alternate suppliers. Send OCUK a webnote about it, if they get enough requests...
just ordered one from the site you are refering to they have 10+ in stock if you check nowWhere can i get the eiswolf 240 for vega? The one place i found said delivery overdue.... Makes me sad. Is there no way overclockers can get some in?
So thanks for that, i'm glad I didn't think of googling it before asking here, because obviously that would be a big waste of time.
I should have googled it first instead of asking people that own vega 56's that have a much larger knowledge of liquid cooling ..........(#sarcasm)
indeed it took less than 10 seconds to find stock thats available. some people are just to darn lazy.
no laziness to it, its only just come into stock. why not try and read the comments fully before posting smart arse comments![]()
They have had stock since just after Lunch.
That's rubbish and I have emails to prove it. There hasn't been stock in at least 2 to 3 weeks. I paid for one weeks ago. The 240 that is.They have had stock since just after Lunch.
-- Vince go back and read what i wrote. I know they did have any stock, i have also been waiting 2 weeks for a 2x 240 and 3x120 sets. I wrote- They have had there stock since lunch. So obviously it wasnt there before that! The reason i know this, I asked them if i could add more to my order, and at this time they said no, I would have to make a new order with the stuff i wanted on it and as such after lunch i made a new order with some more cooling on it, which is also waiting for dispatch on the 11th.
