How on earth did you manage that?
Static electricity I guess? Nothing else to explain it, I do always try to ground myself or touch something metal before hand, but guess it didn't help.
I was unplugging some GPU cables at the same time, reaching at the back of the PC to insert a HDMI cable to my GPU while the PC was running (done it so many times, never had problems) and I guess with me poking the back of the GPU trying to get the cable in, some static electricity from my hand or the cable itself? Must had shocked the sound card in some way, since they close together.
Can't think of anything else to explain it, it was working before and then it wasn't. Just like that.
Now everytime I try to use it, the PC will hang in boot up, which am guessing it's detected the card, but there is a major fault, while also sometimes letting me load up, but Windows won't detect the card or it detects it and loses it again.
The second sound card, the Asus one, Windows won't detect it at all now, but am blaming Windows for that, since it was working before the forced restart and then it wasn't. I did suspect the PCI port itself.
Yeah lessons learned in the end, don't mess with the PC when it's running.
