Guys, can I borrow your expertise on this what I think is a RX Vega 64 problem I'm having.
Problem: I'm getting a hard crash (full system power off and doesn't POST unless I take the power cord off for at least 30 seconds) when I play XCOM 2 game with War of the Chosen DLC. I've managed to save the game just before the crash happens 100% of the time (in case anyone else wants to test it).
System specs:
AMD Ryzen 7 1800X
AMD RX Vega 64
Asus PRIME X370 -PRO
G.SKILL F4-2800C15Q-32GVR
Windows 10 Pro 64-bit
1000W PSU (Corsair HX1000i)
Samsung C32HG70 (1440p 144hz Freesync 2) monitor
CPU and GPU are both water cooled, running at a maximum of about 50 degrees of celcius and should not be a heat problem.
What I've tried:
I've tried all levels of graphics settings from the lowest to the maximum - no difference to the crash.
I've tried 2 different AMD Ryzen 7 1800X CPUs and it has no effect.
I've tried different BIOS versions, including the latest 0902 with AGESA 1.0.0.6b.
I've tried with both Windows 10 Pro N-version and Windows 10 Pro versions, but only in 64-bit.
I don't have another AMD RX Vega 64 graphics card or another graphics card for that matter to test if this problem is specific to this individual unit.
I've tried with ALL different available versions of drivers for this graphics card, and it happens with all of them.
Please note:
I'm getting no crashes on any other game, including Witcher 3, Watch Dogs 2, Overwatch, Nier Automata and other modern games. I've also ran Prime 95 and all Unigine benchmarks extended periods of time without any issues.
I bought the RX Vega 64 on the release day Monday 14th of August and got it the next day (15th of August) from Overclockers. I also bought the Liquid cooling for my whole system including EKWB full cover block for the GPU from Overclockers.
If you guys have any ideas how to test the problem further or even solutions to overcome it: I'm all ears! Thanks!
Ive had similar problem with my system being able to run dx12 api and open gl api but crash resetting on DX11 api, and as weird as it sounds what fixed it was me swapping my 850 watt corsair power supply to my back up 700watt corsair power supply which im still using until i can afford a decent 1000watt
im using msi krait gaming x370 board and ryzen 1700. hope this helps dude because i know how frustrating it can get.
