Just checked via the link I posted and nope, still says £3.99.£4.99 now ,might be worth a punt though
my bad i misread Euros as pounds![]()
Just been playing this and it's pretty good well worth £3.99.Edge of Nowhere is currently £3.99 on the Oculus store. I thought it was average tbh, but lots of other people loved it, and frankly for that price it's a bit of a bargain if you've never played it.
I just bought this but still came out as this (4.99 EUR =4.44022GBP)Just checked via the link I posted and nope, still says £3.99.
Gah, set my new Oculus Rift up last night and all seemed fine. Fired the PC up this evening and the right screen doesn't seem to be working. It's just black. Had a good wiggle of all the cables, reinstalled video drivers and Oculus software to no avail. Anyone else come across this issue? From a quick search of Google, it seems to be a known problem to do with a faulty screen?
Just create a ticket, if you bought from Oculus go to https://support.oculus.com/, otherwise go to your retailer.
Isn't there also an issue with the new windows update causing some issues
What are you plugging it into, and what colour is the little light by the sensor (just inside the face foam, top centre)? The Rift is really fussy with ports and adapters.Gah, set my new Oculus Rift up last night and all seemed fine. Fired the PC up this evening and the right screen doesn't seem to be working. It's just black. Had a good wiggle of all the cables, reinstalled video drivers and Oculus software to no avail. Anyone else come across this issue? From a quick search of Google, it seems to be a known problem to do with a faulty screen?
Some people seem to have problems with driver revisions that cause this problem. Check this thread on r/oculus: https://www.reddit.com/r/oculus/comments/76kq52/psa_nvidia_38792_drivers_broke_my_rift_spoiler_it/Gah, set my new Oculus Rift up last night and all seemed fine. Fired the PC up this evening and the right screen doesn't seem to be working. It's just black. Had a good wiggle of all the cables, reinstalled video drivers and Oculus software to no avail. Anyone else come across this issue? From a quick search of Google, it seems to be a known problem to do with a faulty screen?
Interesting, what did you do to fix them?So just after having my Rift for two days one of
the touch controllers developed a clicking noise when pressing the trigger and the next day the second one is doing the same.
Seriously I have never seen a controller that wears out just after few hours of use.
As I don't want any downtime by sending it back I thought I'm going to open them up and see what's going on.
Turns out that there are some little rubber stoppers to prevent the noise but they are stuck there with a little adhesive and nothing else to stop them sliding sideways.
Design flaw is what it is. I do not understand how could they design it like that as to me it's obvious that sooner or later this thing will get displaced.
Super glued them in place.Interesting, what did you do to fix them?
