OcUK Staff
 - 23 Feb 2015
 - Overclockers UK HQ
You knew this wasn't going to be exciting so don't whinge now!
Let's talk about cable management.
Plastic cable ties have done a decent enough job, cable managing our setups, for over 2 millennia (maybe less, maybe more, i'm guessing). Now however the discerning PC enthusiast is interested in products for cable management which are customise-able, re-usable and looks a damn site better than a clipped piece of plastic.
Label the Cable have your more discerning tastes covered! They make more than just cable labels so you don't have to follow a wire back to your PC or peripheral when you are trying to figure out what to unplug, or playing the plug lottery trying to guess which plugs are live and which aren't.
They have labels for cables (unsurprisingly), velcro rolls, individual velcro loops, command strip velcro wall ties, Cable tubing, as below, and more. The velcro cable ties come in a range of colours for differentiating different loops or cables in systems or on desktops. You can use the wall mount ones for cable managing under your desk or on walls. The products are really versatile and it's one of those whereby how you use it is only limited by your imagination.
Enter Label The Cable:
Product: LTC Cable Tube, Cable Management Cord Cover Self-Closing & Adjustable Cable Cover (black)
Check out the full range here:
https://www.overclockers.co.uk/search?ssearch=label+the+cable
for people who don't want to invest that much time, there are a few examples below to scan through!
LTC Basic, Cable Management Ties (black) @ £4.49 inc VAT https://www.overclockers.co.uk/ltc-basic-cable-management-ties-black-cb-006-cb.html
LTC Cable Management Ties, Cord organiser, Two-sided hook-and-loop tape, Strap remains firmly fixed to the cable, Soft velour quality, 10 Pieces, Re-usable, 17cm, Black
Only £4.49 inc VAT.
ORDER NOW
LTC Roll, Cable Management Tape Roll (black) @ £4.49 inc VAT https://www.overclockers.co.uk/ltc-roll-cable-management-tape-roll-black-cb-000-cb.html
LTC Cable Management Ties Tape, Two-sided hook-and-loop tape, Soft velour quality, Especially gentle on all surfaces, Strong adhesion, Cut to length, Reusable, length 3m
Only £4.49 inc VAT.
ORDER NOW
LTC Pro Roll, Cable Management Hook and Loop Tape (black) @ £32.99 inc VAT https://www.overclockers.co.uk/ltc-pro-roll-cable-management-hook-and-loop-tape-black-cb-002-cb.html
LTC Pro Roll, Cable Management Tape, Two-sided hook-and-loop tape, Soft velour quality especially gentle on all surfaces, Strong adhesion, Cut to length for individual needs, Reusable length 25 m
Only £32.99 inc VAT.
ORDER NOW
LTC Cable Tube, Cable Management Cord Cover Self-Closing & Adjustable Cable Cover (white) @ £17.99 inc VAT https://www.overclockers.co.uk/ltc-...d-adjustable-cable-cover-white-cb-00h-cb.html
LTC Cable Tube, Self closing design cord cover, Can be fitted without disconnecting equipment, Cut to length, Flexible and robust, Resistant to temperatures from -50 to +150 °C, length 2 m
Only £17.99 inc VAT.
ORDER NOW
LTC Mini, Cable Management Ties with Labels (mixed) @ £5.99 inc VAT https://www.overclockers.co.uk/ltc-mini-cable-management-ties-with-labels-mixed-cb-00e-cb.html
Cable labels with hook-and-loop band, Small and inconspicuous, Simple attachment, Reusable, Entire length 9 cm, hook-and-loop tape width 1.1 cm, label size approx. 3 cm x 1.8 cm, 10 Pieces
Only £5.99 inc VAT.
ORDER NOW
LTC Pro Wall, Cable Management Clips Self-Adhesive (white) @ £19.99 inc VAT https://www.overclockers.co.uk/ltc-...ment-clips-self-adhesive-white-cb-00b-cb.html
Self-adhesive cable clips/cable ties with touch fastener, Super-adhesive on nearly any type of surface, Takes 4 cables, Remove without leaving residue, Length 9 cm, Sticky surface is 3x3cm, 50 Pieces
Only £19.99 inc VAT.
ORDER NOW
LTC Wall, Cable Management Clips Self-Adhesive (White) @ £4.49 inc VAT https://www.overclockers.co.uk/ltc-wall-cable-management-clips-self-adhesive-white-cb-00a-cb.html
Self-adhesive cable clips/cable ties with touch fastener, Super-adhesive on nearly any type of surface, Takes 4 cables, Remove without leaving residue, Length 9 cm, Sticky surface is 3x3cm, 10 Pieces
Only £4.49 inc VAT.
ORDER NOW
Only £4.49 inc VAT.
ORDER NOW
Only £4.49 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
Only £5.99 inc VAT.
ORDER NOW
ORDER NOW
Only £4.49 inc VAT.
ORDER NOW
