- 25 Sep 2011
Did you get every component separately just to get more Haribo?![]()
Ahah no, but I was tempted to ask for more, didn't want to be rude
And it's just a kabylake with extra cores really
22 threads? that would be something! Thanks for that info, might contact gigabyte to check, dont want the mobo melting. Do we have an active gigabyte rep on the forum?
Not sure about what to do for the overclock final settings right now, still tinkering around with it. Testing with MT off and think I can get 5ghz under 85c - might offer better performance than MT at a lower multiplier for gaming.
Also letting the core hit 90's probably isnt a good idea, though I never see anything else getting so much heat as prime95, so I'd guess its fine for day to day use
Edit, 10 mins of prime at 5ghz averaged 84c but peaked at 85c - close enough for me
Doesn't look like I'm going to be hitting 5ghz without delidding which is pretty annoying
The annoying is not the must do delidding the action itself, you must do it in all cases!\
The annoying part is that no one can force Intel to reconsider their super stupid bad practice of using chewing gum, instead of proper soldering robots![]()
I'm guessing 9700K will just be a 8700K with proper soldering, good ol intel
Probably do that after the GPU, never oc'd ram before!
5.1ghz 5 mins of prime hit 95c. Didn't want to keep it running that hot so capped it at 5mins
hit max 77c from 15 mins of realbench stresstest. ill do proper benchmarking once all the OC is done/stable
intel only hit 69c on cpu test, mem test hit 75c(?) and vrm only 68c
In theory, you'll stay under those temps when gaming - with games very heavy on CPU side
Yeah, been keeping an eye on it and temps are generally fine, also gpu rarely goes over 50
I'm wondering if I should even bother with prime, seems like since no real world application, or any other stress test can get near prime temps then it's somewhat pointless making sure the PC can be stable while running prime?
I think I can get 5.1ghz stable if I exclude prime from stresstesting.
Also wondering if I can use the CPU boost to boost 1 or 2 cores higher for games not using more than 1 or 2 cores?
blast 10 mins - if it survives and heat is ok - then done !
then work that ram!!!!!!!!!!!!!
Thing is, with other apps not getting past 85c, prime is straight to 100c which is where I instantly stop the test, really dont want the first chip I fry to be from my most expensive build haha.
I don't bother with it anymoreFair enoughI don't bother with it anymore
