Cleaned my shiny steering wheel. It's now matte again.
what did you do with it? mine is quite shinny, I'd like to freshen up the leather.
Start with a clean damp cloth give it a very light wipe just to remove surface soiling. Then use autoglym leather cleaner and really work it in with a cloth or sponge. Leave it for a couple of minutes. Then back to a clean damp one to wipe off remove the majority of the crud. Make sure you keep rotating to prevent rubbing more dirt in. Then a wipe down with a dry cloth to remove the lint!
thanks, going to give it a go and see if it removes the gloss![]()
Topped the oil up on the Zafira for second time in a month
Can't see any obvious leaks, none in the coolant, and no smoke from exhaust so not sure where it's going.
Have left a big sheet of plastic underneath overnight so will see in the morning.
10 plate 1.6 (z16xer I think?) if anyone has any ideas.
Any plastic trays underneath? Don't forget to remove them! Checked the exhaust when the car is fully warm?
I tried the LC:
The road was greasy too and I forgot to full disable TC, but it just hooked up.
I am amazed by how quick this little hatch is, its the ultimate sleeper car.![]()
Btw, petrol or diesel? If petrol pull the plugs and see if there's any crud on any of them
I have a zafira b 1.8 z18xer, when did you last change the oil and oil filter? These cars tend to drink oil like water when oil is old.
