I can't shed any light, hair or skin unfortunately.
Cyberdyne systems model 101.Can't shed hair or skin?? I knew it ... You're not by human!!
What's so amazing about this? I was running a FX-8350 and 290X for a while.I've just realised I've inadvertedly built myself a AMD rig in its entirety.
This doesn't appear to be anything new or amazing.
Still if we're sharing these things, I've just plugged an old pair of headphones into one of my PCs!!!!!!
I just really want the 3rd party cards to be released. Well, if they can deliver better performance (or the same performance at similar cost).
I've owned blower coolers from AMD and Nvidia in the past and I just don't think I can bring myself to do it again. AMD reference coolers are loud before they get to full speed, usually it's by about half way. Nvidia are quieter, but it seems to be because they just use slower fans, or by making them quieter also made them less effective so they need to spin at closer to their max in order to cool the cards. Of course in the past I've kept kidding myself that I'll watercool, but I never get around to it. So now I'm not even gonna pretend.
The Fury X was better, although far from silent. When you stick a 3000rpm 120mm fan on something it's gonna get loud. Even though I've not seen it get to that speed it still goes fast enough that I can't consider it silent. But I don't expect silent, I don't need silent, I just want quiet.
I'd love a nice Aorus or Strix Vega 64 that performed somewhere between the AC and LC versions (like we have with Nvidia and have in the past with AMD).
Oh that's true AMD did RAM and SSDs too didn't they?My last build even had AMD memory..
@AMDMatt
Played SWBF and LOTR last night and
SO RIP GTX 1080.
Wolfenstein II should be fun tonight!.
Have you done any f@h on your TR+VEGA setup?
.Very nice.Modded the MG279Q FreeSync range to 57-144Hz (LFC still active). Capped SWBF/LOTF to 140FPS in driver panel rest defaults. Same in game settings as "usual".
SWBF was so much more fluid and sharp responsiveness game experience. Fury X I used to use stock FS range (max 90Hz) and 88FPS cap and way better experience than GTX 1080. The GTX 1080 was not lack of FPS causing pain, but just as I didn't have G-Sync monitor the lack of this tech usage made experience pants IMO. The GTX 1080 even with V-Sync tinkering, FPS capping, just never felt right to the eye and mind as Fury X. Comparing it to VEGA is day vs night, so experience holds it's own IMO.
Lords of the fallen, even though nVidia title, was better experience on Fury X vs GTX 1080 IMO. And again VEGA rules them both. Yes higher FPS than Fury X from VEGA, from memory. Very comparable to GTX 1080. The experience that FreeSync brings vs no variable refresh tech usage on GTX 1080 words IMO can not convey the delight!
Whilst I played each game I had f@h paused and Steam downing Wolfenstein.
If you do try f@h be interesting to see PPD, etc.
.TLDR: Vega+FreeSync > 1080 without using variable refresh rate tech.![]()
.FTFY.
Without FreeSync VEGA does fall short of GTX 1080 taking into account price and custom cards, etc, etc.
It's mind blowing that 1070 Ti is launching with so many AIB cards. AMD seems to lag behind on this aspect IMO and this time way behind.
Plus it sounds like AMD are trying to fob off all the dodgy C0 edition cores that AIBs are struggling to get working well.
