Permabanned
- 23 Apr 2014
- Hertfordshire
Took you a while
Glad it's working like it should.![]()
hah yeah, dunno if its the different bios or having a bit more knowledge now.
Took you a while
Good work
Is 0052 a new beta bios, are there any changes ?
Test BIOS 0052 fixes the CPU Temperature offset reset after entering sleep mode according to ElmorIs 0052 a new beta bios, are there any changes ?
done over 3000% HCI on 3466 as well as 24hr prime, still doesn't make the machine cold boot any better at that speed, Ryzen is just a little flaky, 3333 is OK for me.
Found the best test in my experience is playing bf1. If it will play an hour or more of bf1 it is stable. Had various tests and bench marks pass but fail in BF1 in under an hour. Bf1 is very sensitive to any instability in overclocks.
So a little perplexed. My R7 1700 + 1080 Ti system has low fps (low GPU usage) and low CPU usage loading The Division and loading maps. Fresh install of W10, latest BIOS and all drivers up to date. My R5 1600 + 1060 system does not suffer from this. The
Fixed it in Nvidia control panelHave you tried turning SMT off? Some games didn't play nice with that turned on with my 1700.
Set what to max exactly?Fixed it in Nvidia control panelset all to MAX
Who would have thunk? Cheers for the reply gavin87.
Max PowerrSet what to max exactly?
