Caporegime
- 8 Jul 2003
- In a house
Id get one if they were under £400
No need to know precise temperature.but your claim of my very probable need to replace it much sooner than otherwise is somewhat over egging it when you don't know the temps these caps are actually subject to.
Agreed, it's incredible seeing 300 fps in the corner. Maybe those 240 Hz monitors are not ridiculous after all.Wolfenstein runs like a dream on vega, wish more games would use vulkan
.you guys think Vega64 will power 3 1080p screens for triple screen setup in Project Cars 2? looking for 60fps, lots of eye candy. I'm doing well over 100fps maxed out at 1440p as it stands, I want to buy 3 1080p's for the triple setup and a racing rig.
FYI Mein Leben does not select Uber Image Streaming, so you need to select that yourself for true maximum settings. You'll want to enable HBCC too.I'm running with V-Sync, otherwise I get tearing on 144Hz screen, 1440P Mein Leben! preset. Even AA isn't slowing it down!.
On just those numbers it looks like you'll be fine. How good are the drivers these days for multi-monitor setups?
FYI Mein Leben does not select Uber Image Streaming, so you need to select that yourself for true maximum settings. You'll want to enable HBCC too.![]()
. I'm running the beta branch, so should have Async Compute active as well.Yes test it per game is what i do. I have it off in BF1.Yes I noticed that last night, I didn't change it so I could compare with past testing. I will be tweaking it. I'm running the beta branch, so should have Async Compute active as well.
Yesterday I did ~6 runs of SP 4K and HBCC off was ever so slightly ahead or no difference, same with 3DM FS. This echos even some of W1zzard's latest testing in COD:WWII. He is using v17.11.1 drivers as well. I'm now turning off HBCC TBH.
Only one, surely crossf oh nevermindId get one if they were under £400![]()
id need a new PSU as well anyway for that, only got an 860w
Gigabyte AMD Radeon RX Vega 64 8GB HBM2 Liquid Cooled (GV-RXVEGA64X W-8GD-B)
Well i've been running it with 3 1440p screens! It stays around 60FPS dipping into the 40's at times with lots of cars around, you dont really notice though with freesync running 7872x1440 is my gaming resolution at the mo.
If I could only get crossfire to work in pcars2 i'd have a go at triple 4k 11808x2160.
Have you tested enabling HBCC for some extra performance?Well i've been running it with 3 1440p screens! It stays around 60FPS dipping into the 40's at times with lots of cars around, you dont really notice though with freesync running 7872x1440 is my gaming resolution at the mo.
There is no recommended settings. As a rule of thumb, if the game uses less than 7GB of video memory, you typically don't need to enable it. However, some games/benchmarks do benefit from enabling it even if they have modest video memory requirements, so you have to test it and see if it adds performance for x application.Still can't my head around the hbcc settings, with 16gb of ram what is the recommended hbcc setting
I was hoping it was just a case of set x amount and forget itThere is no recommended settings. As a rule of thumb, if the game uses less than 7GB of video memory, you typically don't need to enable it. However, some games/benchmarks do benefit from enabling it even if they have modest video memory requirements, so you have to test it and see if it adds performance for x application.
