Cheers mate but it easy to apply and no horrid screenIt's not perfect, I treat my phone every six months with it, it does give the screen some protection.
would a iPhone x in Japan be exactly the same as purchased in uk?
But presumably no warranty in uk?
It isn't, colour shift on the X reminds me of my note 4. current gen panels from samsung are better .The colour shift is way worse than on previous iPhones, even a slight tilt off axis makes the colours completely different... if this is what all OLED phones are like then I don’t understand why we don’t stick with LCD.
One thing that's annoying me and making me actually consider returning the X is that the viewport is actually narrower when viewing websites in portrait than my 7+. This is despite it having a higher horizontal resolution.
I use Techgear ones off Amazon for my iPhone 8. I think they’re about £3. Decent enough. Easy to fit and very clear.Sorry I'm sure it's been asked a million times but what screen protectors are people using for their phone and also what decent cases are out there?
I'm sure it will be fixed, that's a massive waste of space
Thank you mate.I use Techgear ones off Amazon for my iPhone 8. I think they’re about £3. Decent enough. Easy to fit and very clear.
Exactly. https://forums.overclockers.co.uk/posts/31304037
Look at the OcUK forums in those images! The hardware however is really nice though and various peeps on here have persuaded me to try it a little more. I've actually made the effort to install ALL the apps I use and customise the phone properly (wallpapers, sound etc). The question is - will the text be fixed in a software update? I've installed iOS 11.2 beta and there isn't any real change. Apple haven't confirmed anything as far as I know.
I was under the impression that they are current gen, Samsung-made panels.It isn't, colour shift on the X reminds me of my note 4. current gen panels from samsung are better .
They are except made to meet Apple's specification. A friend with an S8 said my iPhone X screen looks better than her phone.I was under the impression that they are current gen, Samsung-made panels.
