Is that measured using power meter/clamp or just from gpu-z core only estimation?v56 trades blows with the 64 and the 1080 when put at the same clocks actually and also my v56 is running at around 180w at 64 speeds so.
As of now it is on par with 1080 and delivers similar performance. Though to be honest the power consumption of V64 would steer me more towards 1080 if it were not for Freesync. I am an AMD fan but I'm not so blinkered I would declare Vega 64 viable competition to GTX 1080 if you weren't tied to freesync.
I'm on the LC card so can't respond directly but have you increased the fan RPM from the stock setting? I know on the LC card the temps can hit the max target without increasing the fan RPM...
+1 with your take on it all.+1. The other gripe currently I would think any potential buyer has is lack of AIB cards.
Just a quick scout on web reveals for ~£30-£40 more than OCUK PowerColor V64 you gain an AIB GTX 1080 without reference blower. If any ref cooler VEGA owner is reducing clocks/voltage to gain quieter experience on VEGA then TBH they've lost performance vs an AIB GTX 1080 IMO. This performance loss may or may not be consequential depending on what frame rates they're targeting. Plus if they have FreeSync I do believe the game experience will be better than GTX 1080 without G-Sync, which sorta nullifies targeting max FPS.
I do not think VEGA was as good as the hype. Besides the wait for launch (plus it's issues) people are still waiting for AIB cards. I would think many are probably dismayed by this.
Here's to hoping AMD really keep pushing out some great drivers and "we" get games which make use of the card well.
It's the same price as ~equal performing Nvidia cards, depending what you want to do with it it's a better/same/worse purchase, looks priced perfectly to me /shrug.
And that's fine, Vega is priced alongside a 1080 and so it should perform accordingly.
The AIO cooled Vega 64 is priced against the AIO cooled 1080, both are noticeably cheaper than AIO cooled 1080ti's.And the £700 Vega 64 LC edition is priced the same as some 3rd party 1080Tis. So I guess it matches that performance across most games too?
But do either of them perform as well, for the same money?The AIO cooled Vega 64 is priced against the AIO cooled 1080, both are noticeably cheaper than AIO cooled 1080ti's.
Depends what you mean? If you're asking if the AIO Vega and AIO 1080 perform ~ the same for the same money then yes, if you're asking if either of them perform as well as an air cooled 1080ti then no ofc not.But do either of them perform as well, for the same money?
The £640 RRP RX Vega 64 AIO, which i bought three of at that price from different retailers, cost the same as 1080 AIO's at the time.And the £700 Vega 64 LC edition is priced the same as some 3rd party 1080Tis. So I guess it matches that performance across most games too?
That would be expected though wouldn't it? Air cooled Vega sits around 1450Mhz, LC sits around 1700Mhz.With the 1080 AiO's boosting to 2Ghz out of the box...
I do not think VEGA was as good as the hype. Besides the wait for launch (plus it's issues) people are still waiting for AIB cards. I would think many are probably dismayed by this..
Yes, but when the the cards were first benchmarked then the Vega LC was barely able to keep with a 1080 FE, whereas the 1080 AiO would probably give another 10-15% performance on top of that. I suppose my issue is with pricing/performance when it comes to the LC/AiO.
OK fair, but I'd imagine the psu is only measuring current draw on the pcie power cables, not factoring in the pcie slot at an additional 20-30 watts if using the stock cooler fan. Or more if watercooling + twin fan rad etc.thats what the psu says, so measured.![]()
But 200-210 watts is perfectly fine, just wish peeps would plot the frequency curve vs fps to show if the investment of aio liquid/or custom water is worth it for the gain in performance compared to undervolted or tweaked vega at it:s sweets pot.
I'd be interested to see if other Vega users can get the following clock, hbm and voltage settings stable, while using whatever the lowest amount of voltage is required to achieve stability. I'd be interested to know what voltage is required to achieve these clocks from AC and LC samples if possible.
With this particular Vega 64 XTX I'm using at the moment, i have achieved the following which is 24/7 stable.
Stock core clocks, but core undervolted 0.075mv. State 6 core clock increased to 1702Mhz.
HBM overclocked to 1070Mhz.
That results in a constant core clock between 1702-1752Mhz.
