I'm sure you've checked already, but a minor boost leak?
ignore that... you mentioned compression is down.
If there's no smoke to indicate a ring land, I think it's time to whip the head off and investigate.
Not something daft like the ECU losing its map or something?
Definitely a mechanical problem with the low compression
After a couple of hours diagnosing and almost of week of pondering I'm still not particularly any closer to working out what damage the MX5 engine has sustained.
Exhaust manifold isn't cracked.
2 cylinders low on compression
Piston crown to top of the cam cover measures the same on all 4 so no bent rods.
No usual noises
That leaves headgasket, but then it isn't using coolant, there's no oil/coolant contamination either. Completely confused
No usual noises
Doubt it would have any compression at all if it was ringlands, nothing in the oil 200 miles ago either.Ringlands?
Couple of valves sticking or not seating properly?
My car battery is flat for the 4th time this week. Need a new battery right now so need to pay Halfords prices.
This is the recommended one when putting my reg in but it seems expensive.
http://www.halfords.com/motoring/bu...year-guarantee-hcb075-calcium-12v-car-battery
The battery that is fitted now is 12v 55ah 255A, the one Halfords are recommending is 550A, seem like too much?
Is that all it cost - Just had mine changed for only £145 - Although the old battery was showing 12.3v in mornings it didn't start the car - Thought new Android radio was culprit but seems a cell had gone. Started fine ever since the change.
Focus 2.0 TDCi - I couldn't have changed it myself as it weighed in at 30kg or there about and it's half under the scuttle -![]()
Brake fluid change. Feels...no different.
