I've posted this on lots of forums already, and have yet to get an answer how to fix this.
CPU i7 6850K
Mobo Ultra Gaming Gigabyte G1 x99
DDR4 HyperX Predator 4x4 3200Mhz & 2x Corsair DDR4 2400Mhz (bought corsair to test other ram)
GPU G1 Gaming 1080
PSU EVGA Supernova P2 650W & Supernova T2 850W (bought another PSU to test another psu..)
Case NZXT H2 Silent Classic
CPU cooler Noctua NH D14 with 2011-3 mounting kit & Arctic Freezer i32 (bought Arctic because I had enought of removing noctua..)
I am getting 5 short beeps, which is CPU Failure according to bios codes. Check videos below for more insight.
Also noticed under mobo some issues BUT I was told Mobo is fine and these have nothing to do with this problem.
https://imgur.com/JjwbFvw
https://imgur.com/1bqBALR
I bought it at **********, then RMA it to check items. they did test it 'three' times I t hink and told me everything was fine even stress test with AIDA64 was completed with no issues. When I tried to get any information from them what kind of components they did use for test purposes i never got that information from them. so I am wondering if I should send it back again, and get proper list of components that they did use, so I can buy the same and test it, which is stupid lol.
What I tried already :
Bought Corsair ram from QVL List (2x4GB 2400mhz) to check if HyperX RAM is faulty.
Breadboarding
Different rams in different slots, the only difference is that in any Channel B PC turn on/off and you can hear a little click in PSU, in any Channel A PC starts and after short while there is 1 standard beep then 5 short beeps.
trying to upgrade bios, removing battery etc.
My PSU and GPU both work just fine as I am using them right now. Problem occurs only when I try to start new build.
Mobo CPU Pins are OK,
TL;DR
5 Short beeps on new stuff
Apparently (according to ********** technicians) CPU is OK, mobo is OK.
Pins on Mobo are OK, CPU is properly placed insite 2011-3 socket.
EPS 2x4 properly conneted too
My PSU/GPU is not faulty, I am using it right now.
Corsair RAM (2x4GB) is from Mobo QVL list so should work just fine
HyperX is not from QVL list
All parts from current build are working 100% no issues, can't test new parts.
So I am out of ideas what to do, any ideas? from my point of view that should work just fine..
CPU i7 6850K
GPU G1 Gaming 1080
Breadboarding
TL;DR
