Are they aiming for 60fps with horizon 3? It may be hard to play coming from playing it on PC. But then pc can't do HDR and i havent quite the grunt to max out at 4k anyway
Not too sure, hopefully, is the original 60/30? Feels pretty smooth if it's running at 30.
I've got it digitally so playing on PC @1440p as well as X1 and it does look glorious but as you say no HDR.
I believe it's 30 on standard Xb hardware at the moment
I flicked between 30 and 60 on pc the other day and it's not that bad. 4k and HDR would make up for that
Was it all right after a reboot? This is one I want to play again.
Ahh appreciate that thanks! I bet Diablo 3 would be nice at 4k!
Anyone played Path of Exile? That's been patched, always wanted to try it. Said to be a great free to play model
I played it the other night, it actually looks pretty good (although not the best animations etc) but I just didn't like the game very much, many may disagree but not a patch on something like Diablo imo.
Definitely get your console exchanged. I had that error as well as many others. Sent the console back to Very for a refund (not exchange, as they said it would take 14-21 days to even check the console). Bought a new one from Argos earlier and everything has installed fine and had a few hours playing on it tonight with no error messages at all.So wouldn't sign in again, hard reset, now I've got an error that says I have to delete my game saves? I seem to have lost them all. Something wrong here surely?
Any ideas which colour depth I should select on the xb1x chaps? My tv is the 49uh661v if that helps. Just that the colours look a bit dull looking. Unless theres a setting Im missing somewhere? Cheers.
Don’t waste your time trying to restore you console and don’t put up with countless errors. The console is faulty - get it swapped!
