This is how good Corsair's Customer support is LOL
8 Dec 2012
UK
How bad of a response can you get ...
Dear Sir / Madam,
I am trying to find out which screws fit the following holes on the 750D case hard drive bay and hard drive cage as I need to fix my hard drives to the tray and the tray to the hard drive cage in order to help reduce vibration noise:
http://i618.photobucket.com/albums/tt265/aniceguy85/forums_keep/750d_hdd01.jpg~original
and ...
http://i618.photobucket.com/albums/tt265/aniceguy85/forums_keep/750d_hdd02.jpg~original
Thank you in advance for your aid
Corsair's Customer Support Response:
Hi Peter,
We don't have a specific screw for just that what we have would be the set http://www.corsair.com/en-eu/accessory-kit-730t-750d-760t-780t here is the link and the screw your looking for would be included.
Thank you
They design a case and then don't have a clue what they have designed.
26 Aug 2013
Person thought you wanted them to send you the screws and recommended an accessory kit which has them included. May have misunderstood you just wanted the name of the screws, as you can find out very quickly in an internet search. Those screw-holes and screws are universal. It's not specific to that case. Same size screws as the four for PSU.
#6-32 UNC https://en.wikipedia.org/wiki/Computer_case_screws
One would think they were giving you the run-around or had flat-out denied assistance or something, given the thread title.
OP
8 Dec 2012
UK
That's a fair comment. That link is extremely useful also! Thanks :)
I've worked out that the normal HDD/ODD screw type secures the hdd to the tray but I am struggling to work out which screw secures the hdd tray to the hdd case.
20 May 2010
World
I just did a build with this case .... and also have lots of vibration noise coming from the mechanical hard drives :(
I have 2 x Mech HD in my rack and it is a pain for noise
If you use mech HD's ... don't buy this case
OP
8 Dec 2012
UK
@lurkio I have managed to reduce my noise issues considerably.
I used the standard HDD/ODD screws from the kit included with the case to secure the mechanical drives to the hdd trays.
I've used the HDD tray screws as indicated in the case manual to secure the trays to the hdd cage. They look like the bottom middle bagged screws in this image.
*** See the following post: ***
http://forum.corsair.com/v3/showthread.php?t=154066
UPDATE to this post found here: https://forums.overclockers.co.uk/posts/31398208
20 May 2010
World
For me its the metal box that holds the trays is what making the noise
I removed the extra one and it reduced the noise a bit
Might try some rubber grommets I have laying about to see if that helps
I do have a load of HD mounting screws anyway, did u remove the rubber ones?
or just add more screws to eash side of trays ?
20 May 2010
World
True of many Corsair cases but not exclusive to Corsair either. In future I'll be trying to move away from having any mechanical HDDs in my main systems at all.
I would prefer to have a couple of storage mech HD's, if something goes wrong you have a chance to recover data, SSD fail are usually fatal to data
The Lian Li PC7 case I had before this had great HD mounting with longer screws with grommets on them
to slide into the mounting recepticals
Man of Honour
13 Oct 2006
Ah yeah - I've a NAS in a rack cabinet out the way for backup which also replicates to external drives in round robin fashion and some cloud replication for certain files. Not a particularly common setup though.
20 May 2010
World
I have 1 x 1TB M.2 , 1 x 1TB SSD , 1 x 2TB WD black HD, 1 x 1TB samsung HD in my main rig
NAS server with 500G SSD + 4 x 3TB in RAID 5
Backup NAS server with 4 x 1.5TB in RAID 5
Both NAS on a UPS
OP
8 Dec 2012
UK
UPDATE:
@lurkio this may interest you.
Recently I started hearing the vibration noises again. So after a good couple of days troubleshooting this, I finally found what works best for the 750D case.
Having the hard drives secured with screws to the trays helps but if you secure the trays to the cage, that seems to help cause vibration noises (a humming sound).
I've got the hard drives secured to the trays but not secured the trays to the cage with them slightly orientated in a way so that the plastic clips don't touch the cage edges :) This seems to work best.
I'm not sure if it is relevant but I also screwed the tray cage to the chassis by inserting a screw behind the front fan into the whole on the side of the tray cage. You'll see it. Also secure the tray cage to the case using the two screws on the bottom (at the front of the tray cage).
I'm contemplating replacing this case after this experience though to be honest.
27 Oct 2005
It was the opposite for me, one of the front panel tabs on my 760t broke so I rang up asking if I could buy the panel seperate rather than another £150 (at the time) case.
They asked for proof of purchase which I'd lost a while back, asked me if I had other Corsair stuff which I said yes (I do), and they posted one out for free at there expense.
win :)
