- 30 Mar 2010
- Exile
Nice little setup, what have you decided to keep in it? Can't be many fish to choose from in a tank that small. I think a few Sexy Shrimp would look great in there.
Picked up some Discus on the weekend at Maidenheads half price fish weekend.
There isn't much choice but not fully decided either. Id like one clown with the intentions of later upgrading to a reefer 170 so it won't live in a tank too small for it although iv seen clowns kept in 22l and i wonder if thats technically okay?
Any recommendations?
I would probably be looking at the smaller goby varieties, the clown or panda may be ok. Or a tiny baby clownfish with a clear schedule to upgrade in the very near future. But as a warning I had a small yellow tang in a 30" cube that I fully intended to upgrade, but life and stuff got in the way, and I ended up having to give it up, which didn't feel great. I was honest with the people in the fish shop, and if they said not to put a certain fish in a tank I wouldn't.
looking for opinions guys.
looking to buy a red sea 250 with the following equipment
1 x Red Sea Reefer 250 in White
2 x AI Prime HD Marine In White
1 x Ecotech Vectra M1 Centrifugal Pump DC 2000 GPH / 7500 LPH
1 x Bubble Magus C3.5 Protein Skimmer
1 x Fluval E 200W Advanced Electronic Heater
1 x Skimz Monzter FM100 Fluidized Reactor
2 x VorTech Quiet Drive QD MP40w Propeller Pump
just under 2.5k for all that. but then i saw the max e 260 range that come with the equipment built in and quite a bit of a saving.
i know the equipment listed above is going to be higher spec than what comes in the max e range.
should i stick to the original plan?
cheers
Why not get the reefer 250 delux wich comes with 2 x ai hydra 26hd’s and the red sea bra brackets instead of paying extra for different lights
It works out about £250 more expensive buying that and the other items seperate. I am on complete aquatics looking at the bundle deal so there must be a discount applied somewhere.
excellent mate thanks for the advice. you wouldnt happen to know which adaptor it is?
cheers
I have a reefer 250. I would recommend downgrading the powerheads to the MP10 (or cheap jebao equivalent if budget is a concern!), the MP40 will be too powerful and you'll end up running them on 10-20%. Be aware that the MP10 might have issues mounting on the back glass due to magnet strength (the 250 has 12mm front/back glass and 10mm side glass). Try to get a skimmer rated for twice your water volume - For bubble magus this would be the curve 5. I strongly recommend getting a temperature controller rather than relying on a heater with a built in thermostat. I use the simply aquaria dual temperature controller with a 200w aqua medic titanium heater. I would be a little cautious with that return, I've read about people having noise issues with them specifically on reefers due to the width of the return piping causing back pressure. The hydra 26 HD are great lights!
No problems with that return pump for me. Beileve @Spook187 uses the same one aswell
what test kit are you using?
