I guess , but for me I don't notice it anymore and when watching a film or using anything is not 100% white screen it's not an issue
I feel the same - my G6 actually has more colour shift than the Pixel which I managed to capture on camera
I have never bought a white phone before but I am sorta regretting not getting the panda edition of this phone now.
but they did have plastic backs not metal.
Don't forget, it's a coated metal though, the coating apparently picks up colours from things like denim.
o2 aren't all that brill in Wales, so no good for me![]()
The mobiles.co.uk deals are tempting. Will be ringing EE for PAC code in the hope they may match it. If not will have to jump ship to O2 or try and get a good Sim only deal and buy the phone.
Played with XL2 and the blue tint is noticeable but only at odd angles. Common apps are white like gmail and chrome so hopefully not an issue with using phone at normal angles day in day out.
I think so pal. You enter it on the website when you check out
i did too, however with the black in my hand, i find this is the nicest black phone i've ever owned. much nicer than the black from the PXL1 which now looks purple black in comparison.I have never bought a white phone before but I am sorta regretting not getting the panda edition of this phone now.
Try this link. You will see all the angles. And if you start to create it based on a photo, you can see it formed even better as you can rotate it to varying angles.
https://store.google.com/category/customizable_live_case
thanks but i want to see a real in life photo from a user
The blue shift isn't there at all during normal, everyday use.
Go into settings, right down the bottom you should see 'support' - you can call/chat from there.![]()
O2 are no good anywhere. There signal is okay, but speeds are abysmal.
Mine has shipped and will be arriving tomorrow from Mobiles.co.uk via DPD.The signal is ok, if you want 2g with some 3g and a sprinkling of 4g yes! Just had a look at the coverage checker and 4g is still shocking here!
Had DPD text but no update on EE site..
Oooooo
I'm really happy with the camera on the XL 2. I wish it had manual controls though.
I'm finding white balance to be off quite consistently inside (it's find outside). There are a few settings to change it, but they're not precise enough
As a point and shoot however, it's incredible
