The method Optoma are using is nothing like interlacing mind - people seem to be missing the implications of "produces independent single-pixel structures".
But it is the same meathod early DLP rear projection TV’s used which is considered inferior
I could put the speakers in the walls?! Lot more work and cost involved..... Really worth it?!
I do agree some of the triple price projectors have better blacks, colour and contrast. But when it comes to 4k and showing the full individual pixels there is nothing wrong with the UHD65.Any which way you want to cut it... its not a native 4k projector.
Early DLP rear projection TV's used the same trick and had a resolution of 520 x 960 and flashed twice
Interlaced HD video and 1080i TV's also had half the resolution on screen alternated the lines to create the full HD image.
Many people wouldn't notice the difference - but its still and inferior image just because 'you' dont notice the difference.
Very few people have the projection screen large enough and sit close enough to that image to appreciate the added pixel information a 4k image can provide - so 'if' all things where equal you could also argue that the JVC's and the Epsons are providing 4k that is good enough for most people not to notice...
The thing is all things are not equal ; The JVCs, Epsons and Sony's have Wide colour gamut (the Optoma lacks this feature entirely) They all have superior blacks - particularly the JVCs, they all have a superior implementation of HDR and none of them suffer from the rainbow effect which is an inherent flaw in DLP technology.
All of these things are likely to be noticed by people.
Not its not the same method. That's what we are trying to explain. If you run the Optima next to the fake projectors there is a massive difference as its not the same method.But it is the same meathod early DLP rear projection TV’s used which is considered inferior
As Rroff pointed out it’s not the same as interlaced video or half resolution. There is a massive difference between the UHD65 4k and the fake 4k projectors that do not display 8mp per frame. With how amazing the UHD65 handles 4k it’s not fair to lump it together with fake 4k projectors that look terrible. What I was trying to get across is the UHD65 is not like the other fake projectors which lose over 2million pixels per frame and look poor at 4k. The UHD65 doesn’t lose pixels per frame and looks great.
Its not exactly the same method and its not just flashing them twice its far more then that.Those early DLP rear projection televisions used exactly the same method that the UHD60 is using - they were not interlaced - the DLP chip had half the pixels of an HD chip and flashed them twice
WGC and HDR are not 4k features and are unrelated to this discussion on native 4k. Yes the triple price projectors have better WGC and HDR although HDR is debatable as a lot people prefer the way the optima looks with HDR but that is personally preference. But that's not what we are talking about.Certainly true that it its making better use of the pixels than other "fauxk" projectors but its still not a native 4k projector and it still gives and inferior version of '4k' features like WGC and HDR
This. I would seriously reconsider if it will be the only screen, they are so washed out in daylight that I wouldn't even consider it.I would never dream of replacing my main TV with a projector, too many compromises for day to day watching, hence why we have a dedicated cinema room for the projector.
A projector is an additional investment over and above a TV not a replacement imho.
The other devices that flash twice do not display the same results as a native 4k projector. The Optima does produce the same results as a native 4k projector when talking about the 4k element. That alone should tell you its not the same method. When talking about the 4k part and if you balance native 4k projectors so they have the same brightness, colours, contrast or as close a you can get to the Optima. Then the Optima displays 4k as good as the native 4k.
There is nothing wrong with the 4k on the Optima and if displaying 4k is your goal then the Optima does a perfect job at it.
). It just isn't a good replacement, and watching strictly on such a screen, for example, will take some of the "magic" away from watching a movie on that screen. If it's for a dedicated cinema room though, then yeah, no TV required.I could put the speakers in the walls?! Lot more work and cost involved..... Really worth it?!
Glad someone said it"do not" put 5 speakers in the ceiling it will sound utter crap
And 1080p is silly big on a 92" screen
Maybe not gaming tho, I haven't tried it yet. Do I not know what I'm missing???
Surrounds can be in ceiling - though I'm not fan of it myself but yeah front left and right definitely should be around ear height and in the direction of the screen - IIRC there is a setup where you can ceiling mount the centre speaker and bounce it off the screen though which supposedly can work quite well but not something I know much about.
The only speakers in the ceiling should be Atmos speakers, or if you have no interest in proper speaker setup and just want audio like in a lift or bedroom.
