Deleted member 651465
Busted out the summer gloves today as the outside air temp had risen to 14C and I thought "why not?"... wish I hadn't now though as the wind and rain have moved in
Next week is meant to be 1-2 degrees in the morning so I'll need them!!!
Or, get on the bike and forget to attach them and wonder why my hands are freezing.
Hey they did the job!!Good choice, 10x better than those muff's you used to bust
I dislike big cuffs personally and still wear them under my jacket even in sub zero. Not sure why, might try it over my jacket next time. I can see the benefit with the wind but doesn't seem to bother me though.
It's literally one plug, the cable runs along your arms and inside your jacket with a controller pooling out the bottom, I'll probably forget to unplug it once or twice but that tiny amount of faff is worth it to have toasty warm handsHeated gloves seem like a right faff. You need them plugged into the bike right? So whenever you need to get on or off the bike you have to unplug them yeah? Can pretty much guarantee I'd forget and get off the bike with them still attachedOr, get on the bike and forget to attach them and wonder why my hands are freezing.
You know it really doesn't seem that long ago that were were sweltering in 30 degree heat at yours, or sat by the pool at lake Como in 35 degree heat...That's the peak temperature here at the moment![]()
Also, I can't believe I dropped you!
Soooo, the KTM 790 duke is £8,499.
As a comparison, the Street triple RS is £10,100.
Same again next year? Minus dropping me though!
I've emailed my local dealer for local prices and release window.
If it's in time for spring and the price conversion is fair then I may end up breaking my no new bike policy rule!
Wouldn't the comparable Triumph be the Speed Triple S? Which is £8200.
If KTM do an R version with at least Bremos and better adjustable suspension then that'd be the one to go against the Street Triple RS.
No, the S model shouldn't even exist IMO, it has the old dash, abs and 2 riding modes, you don't even get radial brakes!!Wouldn't the comparable Triumph be the Speed Triple S? Which is £8200.
Decided to stick with acf50 treating the bike myself this year as I can't get into the "local" allyearbiker guy any time soon. Ordered an electric paint sprayer from Amazon to see if that can get a good fine mist going.
Should be here tomorrow although it's looking a little nippy to be out washing the bike, but I'll probably hide in the shed and try it out anyway.Let me know how it goes mate. I bought some "mist spray bottles" on eBay that just squirted it out in streams...
