so can anyone recommend a cheap 4k projector ?
I've decided to stick with 1080dunno , whats everyone's thoughts![]()
Even though its clear your are joking. The cheapest officially qualified 4k display I know of that that displays full 4k with the full 8million discrete pixels per refresh cycle is the Optoma UHD550X. It’s been seen for around £1500 to £2000. Price keeps jumping around.so can anyone recommend a cheap 4k projector ?
Even though its clear your are joking. The cheapest one I know of that that displays full 4k with the full 8million discrete pixels per refresh cycle is the Optoma UHD550X. It’s been seen for around £1500 to £2000. Price keeps jumping around.
According to the experts as projectorcentral the amount of native mirrors is irrelevant as long as you can display a native 4k resolution per refresh cycle and pass the native 4k 1:1 pixel mapped line patterns without a native chip. All that matters is a full native 4k resolution is displayed which the Optima officially qualified as, by the CTA group. To quote the experts “No native 4K projector can do any better. Practically speaking, the number of mirrors on the chip is irrelevant if it can put 8.3 million discrete pixels on the screen and fully resolve a 4K 1-pixel line pattern.”dunno , whats everyone's thoughts![]()
and pass all the native 4k 1:1 pixled mapped test pattern correctly without a native chip
I have yet to find any tests it doesn’t map correctly and the 1:1 line patterns projectorcentral tested all mapped correctly. But you are right I will edit my post to say all test patterns I have seen and line patterns tested by projectorcentral have passed. Are you aware of any patterns that did fail and still fail in the updated versions?This is a bit deceptive - yes it is rendering 8mpx to the screen with a good level of distinction between pixels but it isn't able to display 100% correct pixel values 100% of the time.
The effect is kind of like running native resolution through an interpolating scaler just for the **** of it.
A native 4k resolution is 8.3millon discrete pixels on the screen in the same refresh cycle. Officially the Optima has that stamp and passes that test and passed all 1:1 pixel mapped tests I have seen and the 1-pixel line patterns projectorcentral ran .![]()
50% of the pixels are interpolated ?but it isn't able to display 100% correct pixel values 100% of the time.
Projectorcentral have a good reputation. It should be pointed out there is a difference between a native 4k chip and native 4k resolution. The projector officially qualified as a native 4k resolution not only by Projectorcentral but officially by the CTA group and the 4k specifications. If the CTA say its 4k then its 4k, anyone disagreeing with the CTA group is just being stupid. They are the ones that mandate the specifications and determine what counts and what doesn't.the second half of the 4K image is a shift diagonally no ?
so presumably the contents of those pixels have to be interpolated from the original source 4K media that had a uniform grid of pixels, so does that not impact image 'quality'
(indeed - do all the pixels have to be interpolated.)
which is a good web site to read up on the technology/limitations ?
If the CTA say its 4k then its 4k, They are the ones that mandate the specifications and determine what counts and what doesn't.
https://www.avforums.com/review/acer-v7850-4k-dlp-projector-review.13830
"not a native 4K projector"
https://www.avforums.com/review/acer-v9800-4k-dlp-projector-review.13706
"Yes, it’s not native"
https://techcrunch.com/2017/07/21/optomas-uhd60-projector-delivers-great-affordable-4k-performance/
"you’ll never know you’re not looking at a true 4K image"
https://www.projectorreviews.com/optoma/optoma-uhd65-4k-home-theater-projector-review/
Don’t fall, however for the 4K UHD hype. Manufacturers tend to want to let readers “assume” it’s true 4K,
https://www.soundandvision.com/content/dlps-4k-really-4k
"despite the lower native resolution on the DMD and its inability to deliver all the pixels of an Ultra HD frame at one time."
