Caporegime
- 18 Oct 2002
Maybe wait until CES in Jan and see what new monitors get announced? Its not that far off now.
Plus new 120Hz 4k TV's are supposed to be coming next year...
Has anyone had screen tearing issues with these monitors? Does this really match a G-Sync monitor for smoothness? Would really appreciate input from owners.
Are you talking about buying one of these and using with a Nvidia GPU?
I have just fitted a 1080ti and will test out in the coming days. SWBF2 seems fine so far, but the HDR seems odd. The game colour is washed out.Has anyone had screen tearing issues with these monitors? Does this really match a G-Sync monitor for smoothness? Would really appreciate input from owners.
Yes... I'm using a 1070 in an "experienced" x58 system.
If you had roughly 9 of them you would create a circle around yourself with a diameter of 3.6m.Would it be possible to have 360 view, multiple 49" monitors all wrapped around you? Then maybe three high.
Yes, it's called VR
Woudn't that break your neck?
doesnt exist, HDR and Gsync dont get along, they are enemies...im looking for HDR gaming monitor and all i see are HDR Freesync
where is the HDR Gsync monitors ?
4K movies with borders - I take it there is no loss of image quality?
Fast Sync on Nvidia - Best way to go for smoothness on this screen? or just cap at 144 and use a mode on the screen like FPS mode?
HDR600 - Now that Windows 10 has the white balance scale in the options which largely fixes HDR gaming on my Sony TV (500-600nit TV) how is HDR on CHG90 now?
No, you need at least a 1600-pixel wide UW monitor for this for the full resolution without black bars above and below (such as the LG 38UC99, I've had this and it's glorious for 4k movies). To clarify, I found that 4k rips look great on the Samsung
Thanks sounds good. Do you use a forced vsync option or preferred option for gaming? Do you use the racing or fps modes?
I have one of these Sammy's atm and find that if I keep the fps above 90 then it's v v smooth (coming from Asus PG348Q)
Still find it quite hit and miss, some games fine and some still don't quite get it right. Still in it's infancy on Windows it seems
Hope this helps
Do you use a specific vsync mode?
