- 9 May 2012
- South Wales
Wow It Does look nice
Update to build ordered Aorus GA-AX370-Gaming 5 AMD X370 (Socket AM4) DDR4 ATX Motherboard and 250GB 850 EVO SSD 2.5" SATA 6GBPS 32 LAYER 3D V-NAND SOLID STATE DRIVE (MZ-75E250B/EU) for build after old motherboard was faulty.
Big thank to @orbitalwalsh for the board recommendation
No probs, if you do have issues , ocuk RMA is normally ace but you know you've got Gigabyte rep support to add that extra layer
Hope mines goes okay. I suspect you get these problems on lots of mobos though? Anyway hope you can post some pics. Ive got the team dark ram too hope it works.I wish I had seen this and the 45 page thread on the b350f before i bought it.Hope mines goes okay. I suspect you get these problems on lots of mobos though? Anyway hope you can post some pics. Ive got the team dark ram too hope it works.
looking good, no way to mount the AIO to the top ? or is it to tight ? cant remember if that AIO is 27mm thick
was too tight thats why had to go at front, might look at 360mm be quiet in 6 months time and also change top 2 fans to 140mm ones
the 280 version is pretty good to, cant remember in that case if going 360 at the front means you have to remove the HDD cage, but then again you might not be using it
can you recommend some 140 fans for top please a a 120 fan for back, i havent seen the 280mm version
thanks sirMy basket at Overclockers UK:
differing colours which is a shame, they do a black and white 140mm but not sure if its on sale for £4 for 2!
CODE
- 2 x Alpenfohn 120mm Wing Boost 2 Plus PWM fan - Green (OEM)= £3.95
- 1 x Two Fan Bundle - Alpenfohn 140mm Wing Boost 2 Plus PWM Fan - Blue= £4.86
want one of the best of the best and have the bank balance
- 2 x be quiet! Silent Wings 3 140mm PWM Fan= £20.99
- 1 x be quiet! Silent Wings 3 120mm PWM Fan= £19.99
thanks sir
wingboost , you can daisy chain the fans together and run them all PWM - handy feature , although helps if they all have same RPM range, 140 might spin slower or faster depending which is lead .
i think with specs i built now always better going for better option, learned that the hard way
Hey can anyone give me a quick TL;DR run down on the problems with the ASUS B350F.
I have a friend over in Holland with one and for love nor money we can't get his RAM to run at anything over stock speeds. Could it be the mobo?
Well I have to communicate over Skype and he's not fantastic at this side of things.whats his overclock ? soc voltage ? ddr voltage ? run soc 1.1 to 1.2 , ddr 4 v 1.4
