Caporegime
- 8 Jul 2003
- In a house
Question is, do you have one or two of them?
Also what have you done with your Fury's?
Just the one (Mrs Wembley
)Furys are just sitting in a box somewhere
Nope, even in GFX score in this bench you still need a high CPU frequency to overcome a CPU limitation.
Something's not right there my vega 64 on air gets that at a held 1550mhz, what actual core clock is that holding in Gt1 and Gt2 and at what voltage?Score 22 718
With AMD Radeon RX Vega 64 Liquid(1x) @1700/1100
And Intel Core i9-7980XE @4.6
Graphics Score 24 874
Physics Score 33 823
Combined Score 10 604
Drivers 17.11.4
https://www.3dmark.com/fs/14349205
Unfortunately my Vega64 is not the best clocker but I don't mind.![]()
Bring it.![]()
Actually CPU does not matter in Unigine Superposition, it's all about GPU muscle.I see that my cpu is never going to allow me to match your unigine score, fancy a firestrike test 1+2 competition? I know i can get 25,000 + on the graphics score there.
Go on then.I see that my cpu is never going to allow me to match your unigine score, fancy a firestrike test 1+2 competition? I know i can get 25,000 + on the graphics score there.
Go on then.
https://www.3dmark.com/3dm/23684501
SCORE 21876 with AMD Radeon RX Vega 64 Liquid(1x) and AMD Ryzen Threadripper 1950X
Graphics Score
25316
Physics Score
31051
Combined Score
8885
I'll let you have this victory Tony.![]()
You can get much better than that, you should be around the 24,000 mark for the gfx score.Slowly heading in the right direction. However I got a lower score once I overclocked the GPU despite achieving higher clocks.
https://www.3dmark.com/fs/14350497
https://www.3dmark.com/fs/14351146
Good score though
How are the temps? If they go to high you will get slower speeds even though the clock of core and hbm will show correctly, the timings will reduce i believe.
Hence why people need to undervolt to overclock.
Also what temp does the card start thermal throttling? I'm hitting low 70s atm whilst benching
Yeah read the wrong clocks. Lets see what you got, homeboy!![]()
Mine does the same. I need to have HBM 1050 @ 975.Last one tanked. Upped HMB to 1050 @ 950 but bench showed it clocked at 800.. hmmm
Yep, if I have mine set to 950mv it limits the HBM to 800Mhz. 960mv lets me run at 1100Mhz or more.Last one tanked. Upped HMB to 1050 @ 950 but bench showed it clocked at 800.. hmmm
