Which is fine for an internet connection, but this is to be able to log onto the modem to look at stats.I have a standard Openreach modem, no commandline configuration required. I just selected pppoe as the connection type in the USG and gave it my login details.
Port Type Duplex Speed Neg ctrl State Pressure Mode
gi1 1G-Copper Full 1000 Enabled Off Up Disabled Off
gi2 1G-Copper Full 1000 Enabled Off Up Disabled On
gi3 1G-Copper -- -- -- -- Down -- --
gi4 1G-Copper -- -- -- -- Down -- --
gi5 1G-Copper -- -- -- -- Down -- --
gi6 1G-Copper -- -- -- -- Down -- --
gi7 1G-Copper Full 1000 Enabled Off Up Disabled Off
gi8 1G-Copper -- -- -- -- Down -- --
gi9 1G-Combo-C Full 1000 Enabled Off Up Disabled On
gi10 1G-Combo-C Full 1000 Enabled Off Up Disabled On
The US-8-150W is (I have 3 of them) and I would be amazed if the US-8-60W wasn't too.
Apparently the fan in the US-16-150W isn't always on but if can spin up when required so I wouldn't call it silent.
The 8-150’s are silent but they do get a bit toasty!
Agreed, my 8-150W is a bit toasty warm and it is only powering a cloudkey and UAP-PRO over POE! Currently only 7watts going out over the POE.
I’d of hit them upgrade buttons a looong time ago
I’d of hit them upgrade buttons a looong time ago![]()
Try turning off the poe on the unused ports. It saves a bit so I’ve heard.
USG updated to 4.14 and upgrading the 300+ APs in work overnight![]()
Took a while to install them all
