Caporegime
- 9 Nov 2009
- Planet Earth
The next Ti will eviscerate this for gaming I imagine as loads of the die is used up by Tensor cores that do nothing unless you are running specialised machine learning software.
Well if you look at the GP102 and GP100,the GP102(471MM2) and the GP100(610MM2) had the same amount of cores,but the former used GDDR5X and had cut down FP16 and FP64 performance,but actually had higher FP32 performance(which is relevant for gaming) since it could boost higher.
