- 15 Sep 2006
- Liverpool
Test server, has performance and graphics suddenly both gone amazing? It looks sharp as a blade, with high fps.
The latest patch changed the anti aliasing system. It looks better now, the previous implementation was done incorrectly so everything looked blurry the higher you had your AA setting.
As for fps the new map is much better optimized (plus no foliage etc) and they've made the old map better on the test server somehow as well. That in combination with fewer overall players on the test server means the test server is performing very well atm. I hope it stays like this when it goes live. The only issue is the rubberbanding but that has gotten a lot better since the last patch as well. Never lasts for more than 2 minutes at the start now, even in high density drop areas.
