- 16 Jan 2005
- Wales
Finally traded in all my Nikon FX gear and moved fully to mirrorless.
Well doneFinally traded in all my Nikon FX gear and moved fully to mirrorless.
Nikon 16-35mm f/4 VR. Went for this over the 14-24mm as it's smaller, lighter, cheaper and I can use my 100mm Lee Filter system with it.
Used, but in pristine condition, £600 delivered.
Good choice, it's a really good lens and probably one of my most used for landscapes. I've got the 14-24 also (which is an amazing lens btw) but generally I only carry it when I know I'll need it, otherwise I carry the 16-35, 24-70 and 70-200.
i have the 14-24 which is amazing and so sharp, but i want to do lots of landscapes next year. I was tempted to swap but i feel i should just dig deep and get both. I'm not sure if i can stomach the massive cost of getting the bespoke 14-24 filter system![]()
I know what you mean about the filter system, I don't have one either but as you say it is such a good lens I wouldn't sell it. On my Iceland trip this year I used it a lot and just bracketed most things that I would normally use a ND/Grad on. For night photography it's amazing and came in very handy inside Ice caves![]()
yeah, it's fine with regards to bracketing as i'm happy to do that. It's just in the instances when a polariser is desirable to cut reflections etc..
