You must have a high wattage ups,, mine will only keep my pc going for about 30mins (about 150watts) and 1-2hrs if its under 50watts.. Im guessing a lot of battery power is used just by the ac/dc converter.. Im guessing it would last much longer if it didn't have to convert the power first?
Question is even more about battery capacity.
Server UPSes tend to have more of it.
Which is why they're usually lot bigger than consumer UPSes and especially extremely heavy.
Also often those have separate extra battery packs.
Like name implies AC/DC conversion is never run from battery, it's only needed for charging battery or in non-battery mode of double conversion/on-line UPSes.
But different inverters (DC/AC converter) can indeed have different efficiency depending on more precise design and components.
Just like PSUs have different efficiencies.
Then again most consumer UPSes actually have advantage in producing (modified) square wave which is simpler to make than sinewave.
Also just like in PSUs higher power output UPS itself tends to need more power to keep itself running.
Though better design and components can obviously help in that.
I myself have Eaton 5P 1550i (1,1kW) with 3x 12V 9Ah batteries and that 16kg weight is extremely light for UPS of that level.
http://powerquality.eaton.com/5P1550i.aspx?cx=101
60mm fan behind stamped mesh is just noise maker, so cut away that mesh and replaced it with adapter mounted 80mm fan which can achieve same airflow at lot lower rpm.
Likely actually improved cooling over original.
			VA is maximum load rating, not necessarily runtime. Obviously a UPS sized for a bigger load will last longer, but normally to get extended runtime you buy additional expansion battery pack units.
Power rating is different thing from battery capacity.
And VA isn't even actual power rating.
It's apparent power unit and doesn't directly tell about actual power rating: watts
You could have many thousand VA load and if it were fully capacitive or inductive it would consume only minimal amount of watts:
Pretty much all electricity would be just "bouncing" back and forth between UPS and load.
While in the past some reactive power component was actually needed with active-PFC in PCs and all better monitors only watts are now meaningfull.
Of course marketers have just stuck to VAs because they give bigger number than watt rating.
