Much needed PC Upgrade
Ok my E drive (second hard drive) won't open now, it says
"The request could not be performed because of an I/O device error"
Triple checked one felt a little loose and then I checked the bios, apparently it had removed itself from bios settings so edited that and now it’s happy! Woooooo!
Thank you all again x
Will edit in a second with pictures without side glass panel on so you can actually see the inside haha
Aww :( it was happy I think it has broken my hdd.
C:\WINDOWS\system32>chkdsk E: /f /x /r
The type of the file system is RAW.
CHKDSK is not available for RAW drives.​
Just seen your pics, that top silent wing. Move it to the front to give more negative pressure . At the moment looks like your running a lot of negative pressure which will sick dust in through unfiltered gaps
