- 25 Sep 2009
- Billericay, UK
The only issue with that is the problem AMD faces in the respective markets. With it's CPU's AMD had a hardware problem, with it's GPU's they have a software problem that's not easy to work around other then encouraging developers to use lower level API's. What they really need is a new front end which allows them to write drivers to force games to take advantage of it's hardware, the problem there is that's complicated and resource heavy i.e costs money which AMD just can't afford or won't do at the moment.I'm personally optimistic about AMD GPU's.
Yea Vega is basically like the FX series of CPU's.
But, prior to rRzen no one gave AMD a hope to pull off what they did with Ryzen.
Presumably Ryzen will take care of it's self over the next 3-4 years so if they can divert all those resources that made Ryzen a good product towards Radeon GPU's then I am optimistic they can make a good GPU series in the next 1-2 years.
