- 6 Sep 2016
a car is designed to go from A to B nothing more . Dacia have a 4x4 thats a fraction of the price then land rover- so why buy a land rover etc
why do you paint your house wall, put down carpet or laminate flooring over floor boards ? just peoples views and expressions
Not the same at all, as I already explained. Difference in cars to suit the job. A computer with LED fans improves nothing to do with core requirements of a computer.
A car with bigger tyres, or more aerodynamic body serves to improve off road handling, or to allow to move through the air with less drag.
A computer fan isn't made "better" with a LED. Unless for example that fan was in a huge array, and you could simply see if a fan failed by absense of light (like fuses with LED that light up when blown)
Paint serves a purpose, by protecting the underlaying surface. Carpet does too, by reducing noise, keeping room warm. Laminate is easy to clean, and it creates a hygenic surface.
Your analogy is not the same to LED in computers.
Just admit LED's are stupid.
