Thanks guys for the tips, you nailed it. Yep, my gain staging was crap. I needed to bring everything down. The main problem was that the backing track needed to come down in the mix much lower. I had kept it at about unity but it was obviously loud enough that my bass drum wasn't cutting through and there was no headroom to push the fader up before clipping.
So I started over pretty much. I muted all my EQ, and just soloed snare and bass drum making sure they're balanced. I brought the backing track down and checked the snare and bass were level with the song and then I added in other parts of the kit and bringing those faders down as well. Took me a while messing around with it but it was good fun.
None of the faders are clipping now, although the bass drum compressor is still showing a little and my final export of the mix showed there was 10.60db clipping. But I'm not worried about that as there's no audible distortion to my ears and I'm really happy with the way the remix has turned out, it's pretty clean. I'll be interested in your thoughts.
It's quite a different sound from the CLA Drums mix. Quite crisp and makes my CLA mix sound muddy to me now. The CLA mix is fatter but softer, whereas this mix is brighter, more focused and more detailed. Snare has more of a crack and woody tone now and more presence. Far from perfect of course, I'm only a noob. I'm just amazed that I could achieve this sound recording from my kitchen. I'm much more comfortable with how many things work in Studio One. I even cheated a bit, I used the split range to adjust volume of individual bass drum and snare hits where I was inconsistent.
https://soundcloud.com/user-689462784/2nd-happy-mix
This is how I ended up with my faders.
