Two that need connecting plus an additional third for optionally connecting to provide more power/stability for extreme overclocking/benchmarking.the Sapphire Nitro+ caught my eye, but it's got 3 8-pin connectors D:
snip
Yeah. Not great, tbh.
Scan has a few after-market Vegas on pre-order for the 31st of January at £750 - the Sapphire Nitro+ caught my eye, but it's got 3 8-pin connectors D:
I don't think I'd see that much difference going from my R9 390 to a RX 580 - it'd be slight IIRC?
I don't fancy Nvidia at all - I swore way-back-when that I'd never buy another based on their pricing tactics. AMD were always the cost efficient choice for me![]()
Nvidias cards are also starting to go for stupid prices as well so your totally screwed.
For £750 you can get a 1080ti. I was with ATI/AMD for long time after ti4200, only switched back to NV with 970 and sadly AMD no longer cost efficient now.
A snip at £999.99
Hi guys.
I've just got a v56 Sapphire Nitro+, as in the offer thread. It's supposed to have RGB LED effects but they aren't showing in Trixx, just no option to enable them, the LEDs around the fan aren't on either. It's not just me who has a card like this from the offer and I've found posts on reddit but no solution other than RMA it, that user got their card from caseking oddly enough.
Anyone else have this issue or a solution?
Cheers for any help
It's a separate software called TriXX Nitro Glow I thought the same thing but found it on the Sapphire website in the end.
http://www.sapphiretech.com/product...D-4931-4156-9DB5-0EFC5453C6D5&prev=1&lang=eng
It's under download which isn't far from the top of the page.
Awesome, you're a star. That has fixed the cards RGB. Still not getting the fan surrounds lighting up, Is there a jumper or something I'm missing? The only manuals enclosed are for the system fan headers and the support brace, ha.
That sounds like something's wrong, Here's mine, If your front isn't lit up like this it sounds like a fault, I've just had a look at the software and I can't see anything that turns just that off but play around with it to see if it changes anything. If not either send an email to Sapphire or talk to them on there own forum, maybe they can suggest something.
Cheers, man. I can see that your's are working fine and you have a 3x8pin pcie variant, mine is 2x8pin. Did you get yours in the OCUK deal?
