You've hit on something there, the price difference between a 1080 and 1080TI is £200, the price difference between a Ryzen 1600 and an 8700K is £200![]()
Haha lucky.
8700K for sure, had the 1700 since launch @ 3.9 plus 3200 CL14 ram and recently swapped to 8700@5 the single target perf increase is lovely.
Nice to see someone post who has actual experience with using both processors, instead of posts of conjecture and opinion8700K for sure, had the 1700 since launch @ 3.9 plus 3200 CL14 ram and recently swapped to 8700@5 the single target perf increase is lovely.
I think i'd trust benchmarks from a respected site such as Hardware Unboxed etc etc over someones opinion regardless of whether they have owned both processors. Lets be honest most people aren't exactly objective. I don't own either processor but i've been keeping up with new developments since AMD started to be competitive again and I certainly wouldn't have recommended a 8700K for a 4k gaming rig unless they absolutely have to have the highest FPS regardless of cost. Even gavinh87 who doesn't appear to be remotely pro AMD, has owned a 1700(x?) and owns an 8700k recommended the 1700.Nice to see someone post who has actual experience with using both processors, instead of posts of conjecture and opinion![]()
In my experience having hands on use of the hardware is much more useful than synthetic benchmarks. Real world usage with someone who has had both systems. Obviously it can depend on what you are actually doing on the system as people have different needs and uses so mileage will vary as usual but I'd trust someone who has actual experience using both systems as a normal user. Those respected sites often have bias and maybe even more so...I think i'd trust benchmarks from a respected site such as Hardware Unboxed etc etc over someones opinion regardless of whether they have owned both processors. Lets be honest most people aren't exactly objective. I don't own either processor but i've been keeping up with new developments since AMD started to be competitive again and I certainly wouldn't have recommended a 8700K for a 4k gaming rig unless they absolutely have to have the highest FPS regardless of cost. Even gavinh87 who doesn't appear to be remotely pro AMD, has owned a 1700(x?) and owns an 8700k recommended the 1700.
There was some good advice given in this thread, unfortunately it was ignored.
Funny enough, I thinking of switching from a R1700 @3.9 to a 8700k. Just need some bit to sell in MM's to cover most of it and then my CH6 and 1700 will go on MM too. Reason behind this, I feel that the 8700k will be quicker and a more stable platform but I will wait for the refreshed Ryzen's first to see what they bring.
@gavinh87 You went from a 1700 to a 8700k is\was the difference, in your opinion, worth the £100 that is will cost me to switch?
For me, definitely. Yes it runs hotter but so would ryzen if it could do 5ghz!
There is no replacement for straight up single core speed, at the moment it is the best no compromise gaming CPU. Older games and MMO's and the like aren't going to suffer like they do on ryzen.
For £100 I'd say yes, its worth it.
Its worth noting that my 1700 CH6 is sat on a shelf above my head, I haven't been tempted to swap back either!
As ive said before, i play Wow thats pretty much the ONLY game i play on PC right now with the very rare odd dabble into ESO and Grim Dawn and WoW runs better on my R7 1700 @ 3.9 than it did on my i7 4770K @ 4.3ghz, so no, im not buying your "MMO's run better on Intel" nonsense as quite frankly thats just not true.
8600k performs better than all the 6 core ryzens, is £240 cheaper than the 1800x and and also outperforms the 1800x in all single core and quad core benchmarks by quite some way![]()
look at the whole and a ryzen chip in gaming is about the same as a 7600k i5. 8700k is miles in front. it will be in front of even the new ryzen.if its a hundred difference do it.
check the benchmarks.numerous ones.8700k is top of the tree in literally everything.you will also see i5 7600k mostly beating even the 1800x on a whole though its about the same as the i5.which compared to the coffeelake chips sucks.
